Pre 84 Trucks 1st gen pickups
1981 22R Fuel Pump
Old Apr 13, 2010 | 07:59 AM
Mike Webster's Avatar
1981 22R Fuel Pump
Has anyone ever had excessive ticking noises coming from their mechanical fuel pump? Is there a new fuel pump that is preferred for replacement? I do not want a cheap one. Input is appreciated.
Mike
Old Apr 13, 2010 | 08:15 AM
seanmearse's Avatar
This one should work for you. As per the ticking, when you pull it, compare it to the new one, make sure all of the parts are present and nothing might have fell into the engine/oil pan.
http://www.autozone.com/autozone/cat...&parentId=49-0
Old Apr 13, 2010 | 08:16 AM
83's Avatar
83
You sure it's not coming from the valves or timing chain? Mine never ticked. I would buy an OEM pump. I had an aftermarket one go out after only about 5,000 miles. Although the guy at Napa said that it was the first time he's ever seen anyone bring one back before...
But they're about $50 at Napa compared to over $100 at Toyota. The second aftermarket one I bought it still holding up now after about 8,000 miles...hopefully I just got a bad one before.
Old Apr 13, 2010 | 09:09 AM
dropzone's Avatar
Fossilized
x2 on checking your valves...fuel pump always carry a spare
Old Apr 13, 2010 | 09:10 AM
fuel pump
Just adjusted the valves and has new timing chain. The noise is definitely coming from the fuel pump. Strange!!! Yhanks for all the input guys!
Mike
Old Apr 15, 2010 | 03:27 PM
Gov't Mule's Avatar
YES! a fuel pump will tick/thump/knock to the point where you think that your little 22R is about to fly to pieces...replace it and you'll be fine. As OC said, it's good to have a spare on hand as well. And there is nothing wrong with the NAPA pumps...you can get 2 of those for less than one at the stealership.
Old Apr 16, 2010 | 08:26 AM
Fuel Pump
Thank You ! That is what I wanted to hear.
Mike
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
