Pre 84 Trucks 1st gen pickups
crank shaft
Old Mar 18, 2010 | 01:57 PM
Jeffp's Avatar
crank shaft
Having trouble getting the crank shaft pulley bolt off. Tried impact already... is it reverse thread? Any suggestions?
Old Mar 18, 2010 | 02:20 PM
snobdds's Avatar
Well you could put it in 4WD and 4th gear and see if the back pressure on the motor will hold it while you use your breaker bar.
The starter trick, where you put a long breaker bar on the passenger side frame rail, pull the coil and bump the starter.
However, I have never met a craftshaft pully bolt that a large impact can't handle.
Good Luck
Old Mar 18, 2010 | 02:21 PM
SoCal4Running's Avatar
Should not be reverse threaded.
I have done the starter trick before but be damn sure which direction you need to put the bar on. Its been a long time and I dont remember.
Old Mar 18, 2010 | 08:43 PM
slacker's Avatar
it's not "reverse" thread .. righty tighty lefty loosy applies .
the starter method works .. just be carfull
Old Mar 19, 2010 | 12:02 PM
83's Avatar
83
I was scared of the starter method so I just used a breaker bar. Spray some liquid wrench or something on it, and get a large breaker bar. Mine really didn't take too much persuasion. Just make sure you look at where your knuckles are going to hit when it breaks loose I learned my lesson the hard way. It really does take a lot of torque, but there's no reason you shouldn't be able to get it with a breaker bar if it's not all rusty or something.
An actual breaker bar works better, but honestly all I used was a 16" piece of pipe on the end of my regular socket wrench.
Scatpac
May 25, 2017 06:47 AM
CratesCruiser
Aug 23, 2015 06:12 AM
Dakotaneu
Aug 15, 2015 07:24 AM
yoterr
Jul 24, 2015 04:29 AM
redneck17
Jul 17, 2015 07:44 PM
