Pre 84 Trucks 1st gen pickups
Distributor/Vacuum Advance Question
Old Apr 8, 2010 | 12:32 PM
thebrick's Avatar
Angry Distributor/Vacuum Advance Question
1980 California pickup with 20r.
The vacuum advance stopped working. I was wondering if this has happened to any of you guys and what you did. toyota no longer makes the vacuum advance or the distributor. So far the only option i've found is to grab stuff off a junkyard truck, and thats not a garuntee. Has anyone found a fix for this? Maybe someplace that sells new vacuum advances? I would settle for buying a new distributor if it came to that, but i would rather not spend the money.
I have tried many different resources in the bay area (toy connection, toyota, etc.) and all have come up empty. Any ideas? Thanks!
Old Apr 8, 2010 | 12:47 PM
82blueyota's Avatar
i have one im not using the vac works on it $50 bucks shipped to your door or check out lc engineering i bought their pro dizzy was like $250.
Old Apr 8, 2010 | 01:44 PM
Gov't Mule's Avatar
look on Fleabay too man...they're out there.
Old Apr 8, 2010 | 02:16 PM
thebrick's Avatar
compatibility
will the distributor from a 22r work on a 20r?
Old Apr 8, 2010 | 07:44 PM
82blueyota's Avatar
i believe it will from looking on the web there is a few treads on pirate that sayes yes
20R/22R hybrid swap writeup
recently, i blew a head gasket. had the head machined, got it all back together, fired it up, and found that i now had a broken valve guide and the head had to come off again
i had a 20R head sitting in the backyard from my original engine, and figured i could try the hybrid that everybody has talked about but you find very few people who've actually done the swap.
i started out with one of engnbldr's complete head rebuild kits with new guides, springs, keepers etc, and bought a set of oversized 20R stainless valves and a 268C cam. i decided i wanted to stick with my 22R carb rather than going back to my 32/36 weber or worse yet, a 20R carb so i ponied up the $30 or so and bought a carb adapter from LC engineering.
the holes in the adapter don't *quite* line up with the ones in the 20R manifold(due to the 20R carb having a smaller secondary and the primary is closer to the secondary) so i got out the dremel and matched them to the adapter.
i also got a set of topline aluminum rockers off ebay. since my 22R is from an '82 celica, it had cast iron rockers, and the 20R had 6 iron rockers and 2 aluminum ones(probably from a repair). i think it ended up being about $100 for a set of 8 + shipping.
i had johnson's machine in tumwater do my machine work on the head. they did the installation of the valve guides, cut the seats for my oversized valves, do a 3 angle valve job with some mild bowl work and surface the head, since it was pretty nasty after 26 years.
as for installing the head, it plops right on the block, i used an OEM 22R head gasket. basically pretend you're installing a 22R head. torqued my ARP studs to 80lbs adjust the valves etc. your 22R distributor will work fine, and EGR is the same(though you're probably not keeping if you're doing this swap anyway). i noticed my LC egr plate on the manifold interfered with the carb adapter, so i took a round file and egged out the hole in the plate closest to the manifold and made a gasket that doesn't stick out as far.
remember, you need to use the 20R intake manifold, since the ports are round vs the 22R intake being square. from the factory, a 20R uses a water-choke carb so there's a water port on top the manifold next to the throttle linkage. the 20R doesn't have the bypass port on the water plate underneath like the 22R, so i took a piece of 5/8" radiator hose, and ran it from the port on the top of the manifold to the pipe on the back of the timing cover.
most 20R water necks will interfere if you have a mechanical fuel pump, so use your 22R water neck.
as for driveability, i kind of wish i had done some more port work. seems to have lost a little on the low end(most likely from the smaller intake ports) but it seems to like to rev. i also have the stock horrible exhaust manifold, but i'll be replacing it with a thorley header before too long. might also look into a single sidedraft setup if i ever find one on the cheap. in conclusion, i'd say unless you have a 20R head lying around or want to do a bunch of port work, it might be easier to just build up a 22R head. i like to rev my engine to the moon, so i'm learning to like this setup
__________________
'79 toy, 20R/22R hybrid with oversized valves, thorley header, offy intake and 32/36 weber
longbeds rock!
82blueyota's Avatar
stole that from pirate
Old Apr 8, 2010 | 07:53 PM
thebrick's Avatar
thanks, i'm going to have to check out pirate
Old Apr 8, 2010 | 09:08 PM
myyota's Avatar
Check out www.rockauto.com they sell a complete distributor or just the vacuum advance for your truck.
Old Apr 12, 2010 | 10:09 AM
Pumpkinyota's Avatar
I don't believe so. However, you can still buy 20R distributors at any major parts house.
Old Apr 12, 2010 | 12:24 PM
thebrick's Avatar
Found a rebuilt one for 100 bucks. Thanks for the rockauto.com link.
oldirtydirt
Feb 23, 2020 09:30 AM
coleypull15
Nov 3, 2015 07:41 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
4Runnin2000
Jul 29, 2015 06:09 PM
88yodabasket
Jul 13, 2015 01:32 PM
