Pre 84 Trucks 1st gen pickups
Help my 22r turns over but wont start
Old Mar 4, 2010 | 03:49 PM
Doug18's Avatar
Well a couple of weeks ago i jump started my truck and then started driving it ... everything got real dim and it shut off and wouldnt start ...i figured it was the battery so i took the battery to advance and got it charged ... i put it back in the truck and the truck sounds like it wants to start ... i pulled the plugs and it isnt getting any spark ... i checked the plug wires and made sure everything was plugged in correctly ... does anyone have any other ideas before i buy a new coil pack?
Old Mar 4, 2010 | 03:54 PM
Doug18's Avatar
the truck was running fine before i jumped it and everything got dimmer and dimmer and shut off
Old Mar 4, 2010 | 03:55 PM
abeD85flatbed's Avatar
it sounds like its the igniter. It is what the coil pack is mounted to. I have never seen a coil pack go bad in these trucks, bt they won't even pop start with a bad igniter. Search the junk yards. They are expensive.
Old Mar 4, 2010 | 03:58 PM
Doug18's Avatar
thanks ill try that
Old Mar 4, 2010 | 04:05 PM
Doug18's Avatar
did they have the same setup in 85+ yotas with the 22re or do i need to try to find a 81-85 in the junkyard?
Old Mar 4, 2010 | 04:07 PM
make sure the igniter is grounded to the fender good as well. the thing generates all of the spark so a good ground on the side of the fender is important. Some year celicas used the same igniter assembly, even some 90 series ran carbs and used the same unit. If you know anyone with another carbed toy you can swap in their igniter and find out if that is the problem real quick. just remember to bolt it to the fender or it won't ground. Good luck.
Old Mar 4, 2010 | 04:08 PM
Look at the plug ends of the igniter are they the standard green ends that are more or less round with a flat side? or are they square?
Old Mar 4, 2010 | 04:12 PM
After the changeover to EFI the igniter design changed. It has to be a carburated model.
Old Mar 4, 2010 | 04:25 PM
Doug18's Avatar
they look standard ... i took some pics
Old Mar 4, 2010 | 04:41 PM
Doug18's Avatar
this is the part i need right?
click here
wtf? $400? hopefully i can find one at a junkyard
Old Mar 4, 2010 | 05:21 PM
Gov't Mule's Avatar
Check all your fusible links first...and before you go shellin out 400 bones for an igniter, read up on these two links:
http://www.pirate4x4.com/forum/showt...gnition+module
http://bbs.zuwharrie.com/content?topic=85514.0
Good luck...please post back when you get it fixt...electrical problems are the suck!
Old Mar 4, 2010 | 05:34 PM
Gov't Mule's Avatar
Oh yeah....also pull your distributor cap and the rotor underneath that and take a real close look at the pickup coil that is inside the distributor under the rotor; make sure the gap is set right (between .004 and .008 if I recall correctly) between the pickup coil and the contact prongs on the distributor shaft. Mine was a little bit corroded once and I had NO SPARK until I cleaned and adjusted it.
Doug18's Avatar
thanks for the links i may look into that if i dont find anything for cheap tomorrow
Old Mar 4, 2010 | 06:34 PM
83YotaNator's Avatar
Have your alternator tested as well
Old Mar 5, 2010 | 12:50 PM
Doug18's Avatar
that wouldnt inhibit it from starting though ... atleast on most vehicles
Old Mar 5, 2010 | 02:56 PM
check for spark on the lead wire coming from the igniter to the distributor cap. If there is no spark and everything else is working, then it's the culprit.
Old Mar 5, 2010 | 04:19 PM
Gov't Mule's Avatar
NOT TRUE! That igniter WILL NOT fire if the pickup coil inside the distributor doesn't tell it to. (no disrespect, just sayin) I know this because I've been there done that.
Old Mar 5, 2010 | 05:17 PM
bone collector's Avatar
make sure the plug wire in the coil is all the the coil itself. i had this happen to me once. plugs cant get spark if the coil isnt giving it to them...
Old Mar 5, 2010 | 07:11 PM
Doug18's Avatar
whats with the dead lead that comes from the igniter?
Old Mar 6, 2010 | 02:07 AM
Gov't Mule's Avatar
thats a diagnostic connection for a tachometer
