Pre 84 Trucks 1st gen pickups
lug pattern
Old Dec 19, 2009 | 07:12 PM
be1464's Avatar
lug pattern
is the fj 40 lug pattern the same as a toyota truck lug pattern and aren't all toyota truck lug patterns the same, thanks
Old Dec 19, 2009 | 07:40 PM
dropzone's Avatar
Fossilized
generally the 4x4 wheel pattern will be 6 lug, 6 x5.5 however you may run into some issues with the backspacings which could affect the brake clearance.
the wheels off my '05 Tacoma would not clear on my '81 due to offset...
2WD's were 5 bolt (edit: with the exception of taco pre-runners-also 6 bolt)
Old Dec 19, 2009 | 08:15 PM
rowdy235's Avatar
Also one thing to keep in mind is the 4runner and pickups/tacomas had a very large center hole in the rims. Larger than most any other stock rim. For example, the rims off my tacoma will fit my buddies chevy, but his rims will not fit the front of mine. Not sure if the FJ's had small or large holes, but just something to keep in mind
kawazx636
Oct 6, 2021 03:03 PM
HiLuxer
Jan 6, 2016 11:34 AM
Cycles
Sep 29, 2015 06:37 AM
larrys93pickup
Sep 17, 2015 07:05 PM
Gutted91
Sep 17, 2015 05:44 PM
