Pre 84 Trucks 1st gen pickups
big brake upgrade Q's
Old Jan 8, 2010 | 03:04 PM
yota81's Avatar
I have done some research about putting IFS calipers/FJ60 rotors on my 81 truck. The only question I have is about the wheel rubbing the caliper. I have stock wheels on my truck now and want to keep them, and have read about needing a 1in. wheel spacer to clear the caliper, but some sites say that i MAY need one, not that it is mandatory. To the people that have done the upgrade, can I run my stock wheels if I do some grinding on the caliper? what exactly is the issue, just the caliper rubbing the inside of the wheel because the caliper is wider?
Thanks
Old Jan 8, 2010 | 03:20 PM
waskillywabbit's Avatar
Caliper might not clear the wheel depending on backspacing. If its just slight then you can grind the caliper down 1/16 to 1/8 and its fine. If not, you need wheel spacers. Just really depends on your wheels.
Old Jan 8, 2010 | 04:20 PM
yota81's Avatar
thanks...that's what i am trying to figure out....just wondering if anyone had run stock wheels with the bigger calipers. i'm running the chrome wheels like the ones that came stock on FJ62s. i believe these wheels also came stock on the SFA trucks.
Jun 1, 2021 01:51 PM
okamikai
Apr 30, 2018 10:19 PM
garagespace
Oct 11, 2015 10:59 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
rondogracing
Jul 14, 2015 07:00 PM
