Pre 84 Trucks 1st gen pickups
weber carburetor
Old Feb 26, 2010 | 07:47 PM
Jeffp's Avatar
Question weber carburetor
Any tricks to installing a 32/36 dgev weber Any help would be appreciated.
THANKS
Old Feb 26, 2010 | 08:37 PM
xxxtreme22r's Avatar
dang I knew I forgot to do something. write up for an 87 coming soon should be the same for you. If you search on here you will find "some" info. But no real write ups. Just did mine, but no write up as of yet except the product review in my "build thread"
Old Feb 26, 2010 | 08:45 PM
seanmearse's Avatar
look in my friends list, contact jonnyboy, he just put one on his 83, matter of fact, the trucks sitting out back, i can snap a few pics for ya in the morning.
Old Feb 26, 2010 | 09:37 PM
StuckinWyoming's Avatar
Just did the conversion tonight on my truck. No pics yet, but it wasn't too bad. Just got it drivable today, will have to clean up the miles of no longer used vacuum lines and finish tuning it tomorrow. I bought my kit from webercarbsdirect.com. I still need to figure out what to do with the hoses coming off the valve cover. I also removed my EGR, so I had to fab up a block off plate for the port on the head on my '82. So far I am very happy with the carb, much smoother and more power.
Old Feb 26, 2010 | 09:49 PM
Same place where I got mine, I just left the egr valve in place with the vac hoses off of it. I did have to get a regulator, and block off the fuel return line from the factory mechanical fuel pump. Set my pressure to 3 1/2lb. so far so good. I do have to richen up the choke though as I don't think it stays on long enough. When it first drops off the high idle my idle drops to 500 RPM. Once warmed up it holds 750 with no problems with the lights and heater on. Without them it runs about 900. I have the high idle set at 2500 because the factory recommended 3000 just sounds ridiculous. For the hoses off the cover I just for the time being blocked off the PCV valve and let the front open to air. Havent noticed too many fumes in the cab yet from it. If I didn't have a leaking oil pan gasket the PCV valve would be hooked up to the old EGR port adapter and the front would be hooked up to the supplied elbow to the air filter.
Old Feb 27, 2010 | 05:37 AM
I probably would have just left my EGR valve on there too, but the flange on it was broken and it was leaking anyway. I put the adapter on the EGR port on the intake and just have a brass plug in it for now. I'm going to mess with it after work today and tidy things up a bit. I think I'll probably hook the front valve cover port to the air cleaner, but I'm not sure on the rear one yet. I'm pretty excited about how much cleaner the engine compartment will look with all of that crap out of there.
Old Feb 27, 2010 | 05:44 AM
the rear one is for the pcv, the weber kit should have come with a barb adapter to put in the place of the egr tube you had to remove to fit the carb on. The hose that goes to the pcv is what goes onto the barb fitting.
Pri$erulz
Nov 17, 2019 08:03 PM
user 82300
Jan 19, 2016 02:01 PM
highonpottery
Nov 22, 2015 03:57 PM
the_supernerd
Oct 1, 2015 09:20 PM
kawazx636
Sep 29, 2015 08:22 AM
