Pre 84 Trucks 1st gen pickups
81 alternator problems
Old Mar 29, 2010 | 04:54 PM
sk8er406's Avatar
My 81 is only getting its power from the battery when I take the positive cable off it dies and the battery isnt getting charged but I took the alternator in and had it tested and they said it was good.
Old Mar 29, 2010 | 04:57 PM
slacker's Avatar
regulator is sometimes the culprit .. but honestly .. I would take apart the alt. and check the brushes .. I would never trust those "counter test props" as I have seen many fail , and been just fine ..
Old Mar 29, 2010 | 06:34 PM
kdo58's Avatar
put a chevy one wire and be done with it.
Old Mar 29, 2010 | 06:52 PM
Kiroshu's Avatar
Alternators fool testers all the time. I would get a new one. Have you had the alt checked with it on the truck running by a "good" shop. Check grounds and connectors on alt
Old Apr 6, 2010 | 07:50 PM
sk8er406's Avatar
Alright brand new battery and alternator but still have the problem. How many wires should be going to the alt? I have 4 the single white one and the three wire plug, is there a ground thats suposed to be connected? Whats a chevy one wire?
Old Apr 7, 2010 | 12:13 PM
thebrick's Avatar
I had the same problem after i fried some wires. My alternator was externally regulated and i had to replace the regulator and rebuild one of those green fusible link plugs off of the positive battery terminal. I had previously taken it to a decent mechanic and he missed the problem entirely. I got the regulator off a slightly different junk yard truck and it worked fine.
You can switch to the chevy alternators, which are internally regulated and only have one wire to connect. they are really simple and can make life alot easier. I'm not really sure of the details though.
80Truck
Oct 12, 2025 07:25 PM
redneck17
Oct 29, 2015 09:09 PM
msane99
Jul 17, 2015 10:13 AM
colinmil
Jul 6, 2015 04:03 PM
