Pre 84 Trucks 1st gen pickups
Need help with my 80 pickup
Old Jun 23, 2016 | 01:14 PM
Curtis1995's Avatar
I just purchased a 1980 toyota 4x4, and it's giving me some problems. I'm hoping someone here can help. Well the guy I bought it from took the engine apart and put it back together. I don't know how it was running before, but it's not drivable now. It will start, but you have to constantly give it gas for it to run, and it sounds terrible. The whole truck is shaking really bad is if it was misfiring, but all the plugs are fine. It instantly dies when you let off the gas. It also has a webber carb on it. Hoping to hear some ideas on what to check out on it. Thanks
Old Jun 23, 2016 | 03:55 PM
slacker's Avatar
9 times out of 10 , the distributor has been "stabbed" in on the wrong stroke . I would check the distributor timing/stroke first
Old Jun 24, 2016 | 11:03 AM
Meatdawg's Avatar
I agree with Slacker, also check that the spark plug wires are correctly placed from the cap to the correct cylinders. I recently replaced a lot of stuff and had 1 wire in the wrong place, it had some of the symptoms you mention. Good luck.
Old Jul 25, 2016 | 08:08 AM
cars-guy's Avatar
yeah check your plug wires and timing. could also be something with the carb like a vacuum leak or something.
77lubr
Jan 15, 2019 08:04 PM
81 4X4
Mar 3, 2016 05:22 PM
Mattsteele
Texas
Jan 30, 2016 11:26 PM
richeyma
Aug 20, 2002 01:59 PM
