Pre 84 Trucks 1st gen pickups
Intro
Old Jan 14, 2016 | 08:34 AM
Old83@pincher's Avatar
Intro
Hey everyone,
New guy here but an original owner of an 83 SR5 4x4 in good to very good shape located in Ontario Canada. (Maybe post a pic sometime). Currently its off highway out of that nasty road salts grips. Now down to business...need info on replacing or repairing wiper transmission linkage. I've worked out plan B which is a bunch of fab and machining new cowl bushing/bearing units out of custom cast aluminum bronze castings that a local ma and pa foundry will do for me. I'm also looking into machining new ones from bar stock bronze(the originals aluminum mounting nuts were seized and I had to cut them out and one of the plastic bushings shattered in the link from the motor to the first pivot) However, I'd prefer plan A which is replace it with something after-market or a good used one. Anyone have one or know were to get? And the 20amp motor fuse seems a little much, I worked out the stall current of the motor one high and got 10 to 12 amps depending on battery voltage...thoughts?
Thanks people!
Old Jan 14, 2016 | 12:59 PM
Terrys87's Avatar
Great to hear you are an original owner. Look in the classifieds as you should be able to find a replacement for your wiper assembly. I would go with a used replacement if it was me. Welcome to Yotatech.
Old Jan 14, 2016 | 05:39 PM
slacker's Avatar
pretty sure I have a good used one ...
email me cj@toyotafiberglass.com if your interested
Kiroshu
May 9, 2024 04:20 AM
86blue4runner
Mar 7, 2016 05:27 PM
jeffb95runner
Oct 28, 2015 03:55 PM
shisha1999
Oct 21, 2015 02:14 PM
UZI - SUICIDE
Oct 20, 2015 09:37 PM
