Pre 84 Trucks 1st gen pickups
clutch and throwout bearing questions
Old Aug 27, 2016 | 08:04 PM
str8yota's Avatar
I am installing a new clutch in my sons 83 with a 22r. I want to make sure I install the throwout bearing facing the correct direction. One side is flat and the other side has a convex curved edge. Which way should it be faced? I have run several searches and have found nothing. A picture would be great if someone has one. Thanks in advance.
Old Aug 28, 2016 | 02:25 PM
Lons81's Avatar
From what I remember, the flat side is against the hub. You can download the FSM from https://www.yotatech.com/forums/f114...ownload-261385
Old Aug 28, 2016 | 10:52 PM
msane99's Avatar
think tapered side inward. kinduv helps center it.
Old Aug 31, 2016 | 08:10 AM
str8yota's Avatar
Thanks for the replies. I couldn't get the fsm to download. The PO had it with the tapered facing towards hub and the flat towards the clutch.
jbaums
May 1, 2016 05:56 PM
weichelh
Apr 22, 2016 11:13 AM
your-real-dad
Engine Swaps
7
Mar 19, 2016 04:50 PM
bill185
Feb 3, 2016 01:15 PM
YoterTillDeath
Jul 4, 2002 03:13 PM
