clutch and throwout bearing questions
I am installing a new clutch in my sons 83 with a 22r. I want to make sure I install the throwout bearing facing the correct direction. One side is flat and the other side has a convex curved edge. Which way should it be faced? I have run several searches and have found nothing. A picture would be great if someone has one. Thanks in advance.
From what I remember, the flat side is against the hub. You can download the FSM from https://www.yotatech.com/forums/f114...ownload-261385
https://www.yotatech.com/data:image/...BJRU5ErkJggg== |
think tapered side inward. kinduv helps center it.
Thanks for the replies. I couldn't get the fsm to download. The PO had it with the tapered facing towards hub and the flat towards the clutch.
