torque rod mod with 3" lift?
Wondering if anyone can tell me if the stock torque rod set up will work with a 3" spring lift without any modifications. I did a little research online and some say only if it's more than 3" it will require modifying the stock torque rod set up. Is this true? If so why would you not need to with any lift less than 3"? Appreciate the help.
Thanx
Thanx
Just installed OME leaf packs they are supposed to give 2 inches i have push pull steering and the only thing i have noticed is now my steering wheel is turned maybe 45 degrees to the left
. Leads me to wonder if i should be concerned about my torque rod, my drag link seems like its at a fine angle.
Definitely looks like the caster or toe is out of whack. Unless that's one of those cool wide angle lenses. Seems like both tires are turned outward at the front
Thanx
Thanx
