Pre 84 Trucks 1st gen pickups
sloppy ujoint/loose yoke.
Old Sep 15, 2017 | 06:42 AM
glitchinq's Avatar
front ujoint on the rear shaft on my truck had tons of slop which is causing some vibrations i have i feel. im going to change the ujoint again but if i recall when i changed it the first time it still had slop.
new yoke? any trucks i can get a spare yoke from that share the same ujoint? there is no chance ill find a 79-83 truck in a local junkyard
Old Sep 15, 2017 | 09:29 AM
dropzone's Avatar
Fossilized
finding the yoke from 79-83 is your best best, later year trucks are going to have a different flange bolt pattern, unless you swap the output flange too.
if you have had a lot of slop for awhile you could also end up with bearing issues on your output shaft
Old Sep 15, 2017 | 12:29 PM
glitchinq's Avatar
everything seems good besides that front ujoint. rear pinion is tight and the flange on the tcase is nice and tight with no slop. i also wouldnt mind having to change out the tcase flange if i can do that. My plan was to change the joint again and tac weld the caps to the flange
