Pre 84 Trucks 1st gen pickups
Changing Instrument Panel
Old Aug 31, 2017 | 07:48 PM
medicmoose's Avatar
My '82 didn't have the gauge cluster with the tachometer. If I replace mine with one from the same year that does have the tach....should the wiring be there so that the tach will work? I assume the wiring harnesses are the same in all of those trucks and the right wires are used depending on the options in the truck...does this sound right?
Old Sep 1, 2017 | 04:03 PM
Lons81's Avatar
My 81 Deluxe cab didn't have stock wiring for a tach. You would have to check the wiring harness to see if yours has the needed wires to the back of the combo meter. They maybe yellow and black
Old Sep 2, 2017 | 05:45 AM
medicmoose's Avatar
Thanks for the info!
