Pre 84 Trucks 1st gen pickups
2" Suspension lift vers Anti Torque Bar
Old Jun 1, 2017 | 04:10 PM
knightflier's Avatar
I'm guessing my anti-torque bar on my front axle has to go to accommodate the OME 2" suspension lift kit that I'm installing-----right? Does this bar really serve a functional purpose? My Truck is a 1982 SR5 4X4 standard cab under complete restoration.
Old Jun 1, 2017 | 05:00 PM
slacker's Avatar
it stops axle wrap in 4WD , it also "tracks" the axle in DD use .
I kept mine on my trekker with no regrets , but most people cut it off
Old Jul 3, 2017 | 02:09 PM
dirtdobberoffroad's Avatar
with push pull steering I would keep it if you go cross over ditch it.
Old Aug 13, 2017 | 08:53 AM
warmonger88's Avatar
I did the OME 2" lift on my 83, you can keep it attached but it make swapping the springs difficult on that side. I removed mine but left the brackets just I case I decide to put it back. I haven't had any issues with wrap, but I mostly DD it, but I expect to add shackles in the near future also.
