Pre 84 Trucks 1st gen pickups
Parking Brake Delete
Old Feb 4, 2017 | 01:44 PM
flg8r22's Avatar
Anyone ever considered this? The 1980 I'm currently working on has the worst rear brakes I've seen. All bad parts are related to the parking brake. I'm not a brake expert but since I've never used the e brake/ parking brake, is this a viable option. Tony
Old Feb 4, 2017 | 01:55 PM
wyoming9's Avatar
Red face
Well as long as you don`t mind adjusting your rear brakes as needed .
Pedal travel gets quite long when they are out of adjustment
As they adjust with application of the Parking Brake
then maybe just plug the brake line going to the rear .
Old Feb 4, 2017 | 01:58 PM
millball's Avatar
Lottsa guys remove all kinds of stuff from these trucks all the time.
It's usually a bad idea.
Old Feb 4, 2017 | 02:10 PM
flg8r22's Avatar
I'll give it a shot in a open field. If all else fails maybe I'll look into disc conversion. Thanks for the thoughts, Tony
Old Feb 5, 2017 | 03:56 PM
slacker's Avatar
if it is a "road vehicle" you might want to check your local laws .. Here , it is a MUST HAVE
Old Feb 5, 2017 | 07:05 PM
flg8r22's Avatar
My daughter also gave me an earful. So I'll keep it safe. I'm hoping the 87 I have has the parts I need. Just looks like the po used the drums to tumble and debur rocks and the brake parts. Tony
Old Feb 5, 2017 | 07:56 PM
old87yota's Avatar
Well... There is a parking brake for a reason....
Just replace the bad parts and have the piece of mind that everything works as it should.
Old Feb 6, 2017 | 08:02 AM
thechief86's Avatar
My 80 pickup has a Line Lock on the hydraulic line going to the back. Works great.
