Parking Brake Delete
Anyone ever considered this? The 1980 I'm currently working on has the worst rear brakes I've seen. All bad parts are related to the parking brake. I'm not a brake expert but since I've never used the e brake/ parking brake, is this a viable option. Tony
Well as long as you don`t mind adjusting your rear brakes as needed .
Pedal travel gets quite long when they are out of adjustment As they adjust with application of the Parking Brake then maybe just plug the brake line going to the rear . |
Lottsa guys remove all kinds of stuff from these trucks all the time.
It's usually a bad idea. |
I'll give it a shot in a open field. If all else fails maybe I'll look into disc conversion. Thanks for the thoughts, Tony
if it is a "road vehicle" you might want to check your local laws .. Here , it is a MUST HAVE
Originally Posted by slacker
(Post 52352124)
Well... There is a parking brake for a reason....
Just replace the bad parts and have the piece of mind that everything works as it should. :great: :safari: |
My 80 pickup has a Line Lock on the hydraulic line going to the back. Works great.
