Pre 84 Trucks 1st gen pickups
Smog question for toyota '79 truck valve assy air switch
Old Sep 18, 2016 | 02:26 PM
truck lover's Avatar
I'm trying to figure out how these connect for smog check.
I circled the pipes to where they should connect.
Three options for red, yellow, and white:
1. air/smog pump
2. air intake assy
3. some pipe coming from behind the engine
part#: 25710-38030
Old Sep 18, 2016 | 04:48 PM
dropzone's Avatar
Fossilized
this is thread on desmogging but i think i remember seeing something about those hose connections in it
https://www.yotatech.com/forums/f114...torial-264405/
Old Sep 18, 2016 | 07:08 PM
rowdy235's Avatar
I just removed mine which looked very similar on my 78. If I remember correctly I believe it was:
Red- Smog Pump
Yellow- Air Filter
White- Exhaust manifold (tube behind engine)
Old Sep 18, 2016 | 10:36 PM
Red- Smog Pump
Yellow- Air Filter
thanks, im trying to smog, do you think i still need the vacuum piping assembly in order for this part to work?
Old Sep 19, 2016 | 02:55 PM
rowdy235's Avatar
Yes I am fairly sure you will need all piping for it to work. Plus if you're in CA pretty sure they do a fairly extensive visual inspection as well.
Old Sep 19, 2016 | 09:11 PM
do you know any good salvage yard or oem parts website i could get some parts?
thanka for the support
Old Sep 20, 2016 | 03:51 PM
rowdy235's Avatar
Not particularly, I'd imagine most of the parts are crazy expensive from the dealer. I'd keep a close eye on the junkyards, maybe find a truck when it first comes in the junkyard and grab all the parts you need
4.34runner88
Engine Swaps
Jan 3, 2017 03:12 PM
dbbowen
Sep 23, 2016 04:57 PM
jtinco
Aug 11, 2016 08:27 PM
4.34runner88
Jun 21, 2016 04:48 PM
Bwyatt1996
Jun 20, 2016 04:32 PM
