Pre 84 Trucks 1st gen pickups
Broken motor mounts??
Old Jul 14, 2009 | 01:43 PM
Sparkys83yota's Avatar
I have a 1983 toyota 4wd . When I am climbing the motor moves up causing the fan to hit the shroud. I am thinking bad motor mounts or tranny mounts. any ideas of what else it could be???
Old Jul 14, 2009 | 01:45 PM
BigBluePile's Avatar
Hmmm, sounds like the drivers side mount seperated. Easy fix, just got to put a new one in.
Old Jul 14, 2009 | 01:52 PM
Thats what i was leaning towards. was just wondering if there was anything else that would cause this before i go start buying a new jack and mounts.
Old Jul 14, 2009 | 02:21 PM
dropzone's Avatar
Fossilized
broken motor mounts are very common-
I am considering a Set of these from 4Xinnovations (just not totally sure they will work with a 1st Gen):
http://4xinnovations.com/pages/drive/enginemount.htm
adding a piece of chain as a just in case is a common fix:
borrowed from the Stub's BlueBerry Krunch Build on Pirate-
Originally Posted by Mr Stubs
Drilled holes in the motor mounts and plug welded a nut in on the backside. This will allow for me to bolt down the chains on the motor mounts (easier to remove the motor)
quickest example i knew of
Old Jul 15, 2009 | 06:46 PM
fyreandwater's Avatar
Same thing happened to my rig. I would replace both motor mounts and the tranny mount. Motor mounts are pretty cheap but no so for the tranny mount.
Old Jul 15, 2009 | 09:53 PM
I already changed the motor mounts. pretty cheap. how bad is the tranny mount?
Old Jul 15, 2009 | 10:13 PM
dropzone's Avatar
Fossilized
i don't seem to have a transmission mount on mine, I have a mount for each transfer case (using 4xinnovations mounts (http://4xinnovations.com/pages/drive/casemount.htm) :
trail gear has a mount extremely similar to the 4xinnovations mount for $69 and a stock replacement mount for $110. Both are compatible with stock crossmembers:
http://trail-gear.com/crossmembers.html
the advantage of the stock replacement mount is that it will be quieter, won't transfer as much gear noise to your truck. You might get lucky and find one a good used one in the junkyard or you can try some of these sources:
Toyota Truck Dismantlers: body parts/axles etc
Davez Off Road: http://www.davezoffroadperformance.com/
Yotayard (colorado) http://www.yotayard.com/home.htm
Jim's Got Parts (Denver, CO) http://jimsgotparts.com/
California Mini Trucks (Cali) http://www.calminitruck.com/
NIX99 (washington state) http://nix99.com/
Rancho Toyota Truck Dismantler (Cali) http://www.ranchotoyotatruckparts.com/
Yotatech Classifields :https://www.yotatech.com/forums/f91/
TTORA Classifieds: http://ttora.com/forum/forumdisplay.php?f=3
Pirate classifieds: http://pirate4x4.com/forum/forumdisplay.php?f=4
Parts Locators: http://www.autopartslocator.com/
http://www.seekautoparts.com/
One thing to also inspect is to make sure all your bolts are in place: transmssion to engine, transfer case to transmission etc. also check for cracked areas
cars-guy
Aug 16, 2020 06:59 AM
Scotto6591
Sep 1, 2015 03:24 PM
keithporter83
Jul 24, 2015 07:37 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
jon.r
Jul 11, 2015 03:34 PM
