Pre 84 Trucks 1st gen pickups
checking gear ratio
Old May 18, 2009 | 07:38 PM
Nimyad's Avatar
checking gear ratio
how do you check your gear ratio. i lifted the tires up and spun the driveline which gave me 2 spins of the driveline for 1 spin of the tire but that seems insanely high. its a 1981 stock pick up
Old May 18, 2009 | 07:47 PM
4Crawler's Avatar
http://www.4crawler.com/4x4/4R_TechI...oDetermination
Remember the factor of 2 factor assuming you have and open differential.
Old May 18, 2009 | 07:51 PM
Nimyad's Avatar
ya i have an open diff so does then mean that my gears are 4.10 to 1 then
Old May 18, 2009 | 07:53 PM
4Crawler's Avatar
Might be 3.90 or 4.10. Best way to tell is as described on the web page above. Use 10 (or 20) driveshaft revs. while counting wheel revs, then divide the ratio by 10. A lot easier to tell the difference of 30 or 41 wheel revs than 3.9 or 4.1 revs.
Old May 18, 2009 | 07:59 PM
Nimyad's Avatar
well thats definetly a lot better then i thought i had but it still seems really fast in first gear. it has the stock 4 speed transmission and i can't find the gear ratios in it
Old May 18, 2009 | 08:01 PM
4Crawler's Avatar
Marlin's page will probably tell you that information:
- http://www.marlincrawler.com/tech/tr...ar-ratio-chart
Old May 18, 2009 | 08:13 PM
Nimyad's Avatar
thanks
Old May 18, 2009 | 08:15 PM
refried's Avatar
You've got 3.90s if it's an '81
Old May 18, 2009 | 08:27 PM
Tofer's Avatar
Sponsor
not always... i've seen 3.73 and 3.42 gear ratios from 1st gen pickups
Old May 19, 2009 | 07:38 PM
Nimyad's Avatar
so im going to run 33 12.50 tires most likely with a dual t cases. should i stay at stock gears or go to 4.56s
Old May 19, 2009 | 07:45 PM
UKMyers's Avatar
4.88's
Old May 19, 2009 | 08:19 PM
Nimyad's Avatar
but i still want this to be my daily driver without getting terrible gas mileage. i also want to be able to go at least 60 with my stock 4 speed
Old May 19, 2009 | 11:24 PM
refried's Avatar
In an 1981 4wd? I've only seen 3.90s in '81s
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
