Pre 84 Trucks 1st gen pickups
81 yota small project
Old Jul 5, 2009 | 10:40 PM
81 yota 4x4's Avatar
im doing a front end rebuild, brakes(rotors, drums, longer brake lines) and bearings all the way around, redoing the wiring[battery wont charge(i think its a bad ground) and turn signals dont work] and painting it. and a whole long list of all the little stuff that can wait, ex. window rollers, windshield, patch the holes in the floor, and bolt the seat in. and then theres the never ending list of stuff i just want like: dual batteries, dual transfer cases, winch, rollbar (or maby an internal rollcage), lots of lights, cb, pa, ext.
ill be 16 this aug and i have 1500 to spend on the truck untill i get a job,
the truck its self is an 81 and has about an 8 in. lift, 36" tires, flowmaster exhaust, and a beautifuly running 22r, ill probly have lots of question along the way. so far ive pulled the bed off put it on jack stands and pulled the front axles out,
Old Jul 6, 2009 | 10:48 AM
TroutEhCuss's Avatar
I like you front bumper! My wife slid and bent mine.
What do you plan on doing to the bed - I see that it is off? Also, what kind of gas milage do you get with an 8" lift?
Old Jul 6, 2009 | 11:00 AM
bxlt's Avatar
Nice truck have fun and good luck. I would have KILLED for something like this when I was 16!!! You are one Lucky kid!
Um I don't know everything about trucks but I don't think the 8" of lift will effect the gas mileage, now the 36's would
Old Jul 6, 2009 | 11:02 AM
bxlt's Avatar
Yup new sig line found!
Old Jul 6, 2009 | 11:58 AM
i took the bed off just so i could sandblast and paint, and i figured i could get to the wires easier. ill put it back on when i get it goin. and i drove it home(orting) from olympia and a lil bit around the nieborhood when i bought it, so i havent really drove it enough to see about gas milage.
Old Jul 6, 2009 | 01:11 PM
I would have killed for a truck like that at 16. Take care of it and you'll have stories for a long time.
Old Jul 8, 2009 | 07:13 PM
im currently tryin to get ahold of a front end rebuild kit and some drums/shoes, then ill need the front leaf springs cause there shot
Old Jul 8, 2009 | 11:31 PM
Who is helping you with the work?
Old Jul 9, 2009 | 10:05 AM
actually alot of people, my dad, my niebor moose, my buddy shane, collin and ty
Old Jul 9, 2009 | 11:22 AM
oldgold3vze's Avatar
How's that Weber workin' for ya? Which one is it?
Old Jul 9, 2009 | 01:22 PM
it needs tuned, and idk which one it is.
Old Jul 10, 2009 | 05:51 PM
i learned that front end rebuild kits are a month out every where, which sucks cause i really didnt want to wait that long
Old Jul 10, 2009 | 06:30 PM
ILLINOISYOTADAWG's Avatar
try partstrain.com i've had good luck with them imo
Old Jul 10, 2009 | 10:38 PM
thanks a lot it looks like ill be able to find a lot of the parts i need with that, a lot. but i couldn't find a front end rebuild kit. it looks like ill use that site a whole lot. i book marked it
Old Jul 17, 2009 | 10:29 PM
i found a front end rebuild kit i bough it and some bearings from this guy in enumclaw that i think ill git to know well. all i need now for the front end is calipers.
i have these lift blocks in the front that look kinda sketchy to me but my dad says there fine. should i get taller springs or just live with it for now?
Old Jul 25, 2009 | 07:53 PM
Old Jul 25, 2009 | 08:26 PM
yotaboy82's Avatar
holy cow i think u need new from springs. i thought mine were bad
Old Jul 25, 2009 | 09:10 PM
shaw_j's Avatar
Mother of god you have a block!
A lift block in the front of your truck!
NO WAY
Old Jul 26, 2009 | 08:23 AM
refried's Avatar
It's not only a lift block but also an overload spring, I also see a longer shackle in back. Buy some new springs and get rid of that block and shackle before you drive it on the road. There's no need for all that lift, you can fit those tires with a lot less.
Old Jul 26, 2009 | 09:31 AM
holy cow you guys are mind readers, thats exactly what i was gonna do. i was gonna get new leafs and get rid of the block, no way would i leave it like that. when i bout it it sat level but i think it still will if i get new leafs and ditch the block., but actually the tires rub the frame in the back in flex
