Pre 84 Trucks 1st gen pickups
81 yota small project
Old Jul 27, 2009 | 06:31 PM
81 yota 4x4's Avatar
Old Jul 27, 2009 | 06:32 PM
Old Jul 27, 2009 | 06:34 PM
Old Jul 28, 2009 | 06:10 AM
brooklee1000's Avatar
Love the hand grenade shifter knob!
Old Jul 28, 2009 | 06:25 AM
  #25
Lumpy's Avatar
Looks like you have yourself a nice lil project. You treat her right and she'll do ya right!
Old Jul 28, 2009 | 07:30 PM
  #26
painted the axle housing
new (used) leaf springs
messy garage
Old Jul 28, 2009 | 07:33 PM
  #27
i hit a couple of questions, 1: when i was taking the front end out i ook some shims off that i thought were just plates, now i dont know which way the go. does any one know??
2: are these suposed to be different?( wraps around the axle housing for the ubolts to go through)
Old Jul 28, 2009 | 09:39 PM
  #28
another question. i have a 4 speed manual in it right now but i also have a 5 speed in the barn outside. a buddy of mine was talkin about how another buddy of mine with an almost identical setup couldnt touch 5th gear. he said i should get the tranny re-geard so the gears are lower so that it would be like a 4 speed with a granny low, untill i heard this i was just gonna run dual t-cases. does anyone have more info on the topic for me? gearing is kinda confusing for me.
Old Jul 29, 2009 | 08:11 AM
  #29
cblackard's Avatar
These are shims that twist the pinion upward to relieve some of the stress on the ujoints for a lifted truck (I believe they are ~ 3 degree shims) They should be placed such that the thicker side is facing towards the front of the truck. You will understand when you place them between the springs and the spring pads.
As for the u-bolt backets, I believe mine are similar in design. I would bet the one on the left is for the passenger side since it has to work next to the "pumpkin" in conjunction with the spring pad type piece welded to the bottom of the housing
CB
Old Jul 29, 2009 | 08:41 AM
  #30
Tofer's Avatar
Sponsor
i would get a ubolt flip kit for the front... well worth the 50 bucks.
looks like you got a sweet lil project there.... let me know if you need any Trail-gear parts. i am a TG dealer and live just up in tacoma....
we should go wheelin sometime!
Old Jul 29, 2009 | 10:15 AM
  #31
awsome thanks for the help
Old Jul 29, 2009 | 10:33 AM
  #32
83's Avatar
83
I don't know about regearing the tranny, but you could definitely regear the axles. The axle/differential is what people put different gears in to help with bigger tires. So yeah, your gears are for 28" tires. You put those big tires on and your gear ratio to tire size is thrown way off so you lose all your power. Going to different gears (like 4.88 or so) will return you to close to stock set up, so you'll actually be able to move those tires. Not sure what the effect of the dual t-cases will be on this, but I don't know that it will effect your 2wd performance at all.
Old Jul 30, 2009 | 03:26 AM
  #33
cblackard's Avatar
This site has several calculators to use for regearing. I was using 5.29:1 gears with 38" Swampers and the stock V6 with excellent results. The speedometer was even close to being accurate.
http://www.offroaders.com/info/tech-...alculators.htm
The trick is if you get it wrong, you have to live with it or buy another set of gears. If you are not sure about the gear ratio you want, or you get a ton of conflicting suggestions, try the calculator and buy just the set for the rear axle. if you think it's too much or too little, change it out accordingly. Then buy the matching gears for the front.
CB
Old Aug 2, 2009 | 01:30 PM
  #34
yeah ill probly use that but i just want to get the thing road worthy for now so i can get to school
Old Aug 3, 2009 | 10:39 PM
  #35
i want some trail gear axles but i dont think i have the money for em now so ill probly have to use what i got for now, but could i get a price for the entire birfield axle assembly?
Old Aug 4, 2009 | 09:52 AM
  #36
Tofer's Avatar
Sponsor
are you asking for a quote for the dirty 30s and hub gears?
Old Aug 4, 2009 | 10:47 AM
  #37
yes? maby, i want axles and birfields, whats a dirty 30
Old Aug 5, 2009 | 11:33 AM
  #38
i think i just need the dirty 30's (i looked it up)
Old Aug 5, 2009 | 06:12 PM
  #39
its back in, no blocks
Old Aug 17, 2009 | 10:25 PM
  #40
old birfield
4 piston calipers and green hub indicater
rear axle housing
rear diff(rust)
