Pre 84 Trucks 1st gen pickups
truck wont start, it's my fault
Old May 10, 2009 | 06:11 PM
nord77's Avatar
My truck started missing yesterday, so I took a gander under the hood. One of the plug wires (#3)had simply fallen off the plug w/the connection attached to the plug. There has been some oil hanging out around my head gasket so I used this as an excuse to purchase a compression test set, pulled the plugs and ran through the cylinders. Everything checked out fine, but I flooded the hell out of my engine and forgot to take note of the cylinder to distibutor cap relationship. Hey guess what!! my truck wont start.....my truck came with a 22r fsm and that is what I followed for the clockwise wire setup... any Ideas. I searched under stupid mistakes and did not find much to do with my problem. Oh, it turns for a second and then kinda backfires, repeat, I also used one of those make your own wiresets things. Maybe I messed that up??? you guys rock. Thanks for any help.
Zac
Old May 10, 2009 | 10:19 PM
scooper's Avatar
Look on the dist cap, it should have the firing order. Front to rear, 1-3-4-2 if i remember off the top of my head. Did you loosen the distributor at all and "adjust" on the timing/advance at all? Set the distributor back in with the rotor button at roughly the 12 o'clock position and it will be close enough for you to adjust.
Badger62811
Jun 26, 2015 09:26 PM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
Luke
Jul 8, 2002 04:22 PM
