Pre 84 Trucks 1st gen pickups
'80 4cyl. 20R water pump bolt torque specs? I got the 6cyl. specs thou...
Old Jul 5, 2009 | 03:54 PM
Arie_Dub's Avatar
Exclamation '80 4cyl. 20R water pump bolt torque specs? I got the 6cyl. specs thou...
What are the '80 Toyota 20R 4cyl. water pump bolt torque specs? They are not in th manual they just have the 6cyl specs, which are:
14ft/lb for the thermostat &
13ft/lb for the water pump...
Should i do them @ 10 ft/lb & see if it leaks???
NE1?
L8R DAZE????!!!!>>>>.... ARIE...DUB-THE-WIZARD
Old Jul 5, 2009 | 04:01 PM
slacker's Avatar
do you actually have a in/lb torque wrench ? obviusly a regular torque wrench wont work ..
on that note .. 12 in/lb .
ohhh ... and welcome aboard .
Old Jul 5, 2009 | 05:22 PM
Arie_Dub's Avatar
the manual is in ft/lb and so is my wrench!
so, '80 4cyl. 20R water pump bolt torque specs are 12ft/lb?...
L8R
Thx
ARIE
Old Jul 5, 2009 | 05:59 PM
slacker's Avatar
ok ..
so basicly , I will take my socket and rachet .. and tigheten it "hand tight" , I dont actually use my torque wrench , just done "by feel"
Old Jul 5, 2009 | 07:34 PM
Arie_Dub's Avatar
Thx, i've been look'n online & post'd in a bunch of forums with no luck, but u'r the only 1 who replied THX AGAIN
Arie
80 4x4 4spd 20r 2.2l jack'd w/original bed
Old Jul 5, 2009 | 07:44 PM
Arie_Dub's Avatar
12in/lb=1ft/lb...
what if i use anti-seize?... less torque!?
Arie
Old Jul 5, 2009 | 08:05 PM
slacker's Avatar
yep .. 12ft/lbs is correct ...
guess I just dont know my own strength
Old Jul 5, 2009 | 08:36 PM
slacker's Avatar
never had a problem with "neversieze" I always use it ..
2 are studs with nuts . the rest bolt into the timing cover .. 1 bolt goes right threw .. use it on all of them ...
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
TammyMarie
Jul 15, 2015 11:14 AM
Jonny246
Jul 12, 2015 04:51 AM
cars-guy
Jul 11, 2015 07:51 PM
