Pre 84 Trucks 1st gen pickups
new timing chain
Old Jun 10, 2009 | 05:11 PM
slisdexia's Avatar
new timing chain
I'm putting a double row timing chain kit in my truck(83 p/u, 22r) and seem to have run into a problem. I can't get my crank pulley back on all the way. Do I need to shorten my oil pump spline? If so, how much? Thanks in advance
Old Jun 10, 2009 | 09:22 PM
slacker's Avatar
you actually need the double row pump spline ..
I have one at my shop I'm sure .. I could measure it for ya if you want to cut it ? your best just to buy one , or get one from the wrecker though .
Old Jun 10, 2009 | 09:53 PM
slisdexia's Avatar
if you could measure it, that would help me out a ton. The yards around here seem pretty picked over but I'll see what I can scrape up.
Old Jun 11, 2009 | 05:45 AM
kdo58's Avatar
there are two different oil pumps one is thicker than the other.
Old Jun 11, 2009 | 06:28 AM
slisdexia's Avatar
I do have the right oil pump, already tried with the wrong one and that just didn't work at all! I'm going to head on down to the junk yard today to hopefully find a 20r
Old Jun 11, 2009 | 08:13 AM
83's Avatar
83
Good luck! Next time I need a new chain or rebuild (hopefully not for a long time), I'll be going with the dual chain.
Old Jun 11, 2009 | 04:31 PM
slacker's Avatar
I have dont tons of these , and the oil pump size is a non-issue .. really the only differince you should be interested in , is the Turbo pump is a hi volume .. the rest are just normal .. The hi volume is really not necessary though .. not on a stock engine .
here ya go ...
you would have to "cut " both ends , if your going to cut it .. but here is a pic for ya ..
and I figured you could measure yours !
Old Jun 11, 2009 | 06:06 PM
slisdexia's Avatar
great, thanks! took it down to a local machine shop and got it turned down on a lathe for the low price of free.99! The truck is getting closer to running... I love this forum
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
razorman8669
Jul 12, 2015 12:13 PM
