Pre 84 Trucks 1st gen pickups
problems on the highway
Old Jun 5, 2009 | 08:51 PM
yotaboy82's Avatar
ok soo today is the first day my truck was register and i wanted to take her down the highway and around 70 km/h, she started bucking and jerking i changed the fuel filter and cleaned the carb but i have yet to test it out....but anyways here are some pics, and what you are about to see is CRAZY!!! and yes this ISSS the same truck iv always had
WENT FROM THIS!!!
TO THIS!!!!
Old Jun 5, 2009 | 09:15 PM
georgiayota's Avatar
If replacing the filter and cleaning the carb didn't stop the bucking, it could be the clutch.
Old Jun 6, 2009 | 06:00 AM
scooper's Avatar
Clutch or fuel starvation still. (improperly tuned carb?) Possible timing problem as well bud.
Old Jun 6, 2009 | 07:35 AM
yotaboy82's Avatar
the clutch is brand new, less than 100 km on it but when it starts bucking and i pull over and shut it off, i notice my float bole is empty, then i manually fill it again and its good for a while and it starts bucking again, so we will see
Old Jun 6, 2009 | 09:37 AM
How about your fuel pump?
Old Jun 6, 2009 | 11:05 AM
yotaboy82's Avatar
just replaced it today, got pulled over for not having tail lights, so i need to fix em beofre driving it again LMAO
Old Jun 6, 2009 | 04:39 PM
brooklee1000's Avatar
Sounds like fuel filter. Carb is starving, not getting enough fuel.
Old Jun 6, 2009 | 11:51 PM
I would blow throught the fuel lines with an air compressor, you might have some trash in there somewhere.
Old Jun 7, 2009 | 08:21 AM
Kiroshu's Avatar
have you had any carb work done to it? if the float bowl is not staying full all the time your float could be bad..... replace the float and see if it helps. if not may be time for carb rebuild. If the clutch was not new i would ahve thought of clutch slipping.... thats usually when it does it is at high gear. low fuel pressure.... its not leaking gas anywhere is it?
Old Jun 7, 2009 | 05:52 PM
yotaboy82's Avatar
ok i fixed the problem, i took my carb apart and blew out every passage with a aircompresser and it fixerd it instantly. i dident replace anything, been driving it all day today and not a single problem
Old Jun 8, 2009 | 05:30 AM
83's Avatar
83
Did you find a bed? Didn't you make a flatbed? Looks good!
Old Jun 8, 2009 | 01:45 PM
dropzone's Avatar
Fossilized
Cool, lowbuck/free fixes are the best.... before or after you fixed your Taillights
Originally Posted by 83
Did you find a bed?
looks like it
Old Jun 8, 2009 | 02:35 PM
Cascade4Byer's Avatar
looks good. whats next?
Old Jun 8, 2009 | 07:10 PM
yotaboy82's Avatar
looks like it
LMAO this was after i fixed my taillights lol,
Old Jun 8, 2009 | 07:12 PM
yotaboy82's Avatar
shure did, i found a complete truck here for 650, the bed has fiberglass bed sides on it so no more rust the tires are 33'' x 12.5, 15rt Micky thompson baja claws
Old Jun 8, 2009 | 07:14 PM
yotaboy82's Avatar
next is hopfully a complete 22/20r hybrid
Old Jun 8, 2009 | 07:15 PM
yotaboy82's Avatar
so me and my friend did some driving around todayin the mud and i got some cool pics in
Liadrin
Apr 25, 2022 02:54 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
Liadrin
Sep 1, 2015 06:44 AM
kyletbert
Jul 17, 2015 11:39 AM
