Pre 84 Trucks 1st gen pickups
81 pre-runner HELP!!!!
Old Jun 6, 2009 | 09:56 AM
81yotafan's Avatar
I am trying to make my 81 pickup 4x4 into a pre-running bad ass. My plans are to put a small block 302 in to loose the front axle and make it a 2 wheel drive but putting a front end in from a tucoma or 85-89 pickup. After that put in a total chaos suspention and flaired fenders. So what im trying to get at is am i going the right way or is this to much to ask?? So if you have any pointers or advice im all ears!
Old Jun 6, 2009 | 10:20 AM
eighty5yota's Avatar
sell your truck to someone who will actually use the 4 wheel drive and get a 86,87 2wd.. theres no use in killing a good truck like that..it will also give you a starting point for your long-travel setup and cure the need for a IFS swap to a SA truck if you go with that ford engine, youll be changing everything from the flywheel back.
i havent even gotten started on the frame either.. your vision of wanting it to be a 'badass' with a ponypusher under the hood is not possible without major frame mods for the 302. the best bet is a full tube frame if you really wanna jump it.
your looking at
engine price(and all the other related crap you have to buy to make that work)+tranny+driveline+rear end+linking of suspension+startup truck cost+chaos lift kit price+king shocks.. i know theres more i forgot too. ALSO if your not doing it yourself then double that price..
Ned
9
Apr 11, 2009 08:11 AM
peckm888
Aug 5, 2008 01:49 PM
KLOUN
50
Aug 1, 2004 08:54 PM
