Pre 84 Trucks 1st gen pickups
20r get'n hot need help !!!!!
Old Jul 16, 2009 | 06:17 AM
booger 746's Avatar
O.K. need'n some help.
Have me a beat'r 1980 2wd yota pick-up.
Love this little beater !!
I've drove it about a year now and temp guage always runs a little over half.
About a month ago she started run'n in the RED !!
Pulled thermo stat thinking it was stuck, could not see much circulation in RAD.
Drove 5 miles still got hot.
Checked Rad for Circulation, has real gooooood circulation, pump is good I think !?!?!?!?!
Put thermo stat back in, still has good circulation !!!!
Noticed clutch fan not kicking in, put new on, kicks in good but still gets HOT !!
Next I thought temp guage messing up. Pulled wire from block (Engine was Hot) and guage bottomed to cold. Plugged back in went back to hot (engine was Hot, did I already say that) I think guage is working !!!
My next step I think is to check RAD to see if it is full of dead bugs or whatever blocking air flow. I am going to pull and power wash RAD being carful not to damage.
I have a feeling this is not going to help, I hope it does, but have a feeling it will not.
What should I also be checking ????
HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!
Old Jul 16, 2009 | 05:12 PM
slacker's Avatar
I think your on the right track ... chances are it's the rad ... unless someone has "dumped" some stop leak in to the cooling system ..
go to er' with the power wash . I might also suggest "flushing" the whole system with a "hose T " and replacing the coolant .
Old Jul 27, 2009 | 06:05 AM
booger 746's Avatar
I do believe I got her whipped !!
It was the thermostat !!!
Thing was stuck open, letting it flow through to fast I guess.
Put a genuine toyota thermostat in instead of a "parts" store one. 10 times the quality when looking @ them side by side !!!!
Old Jul 27, 2009 | 08:19 AM
83's Avatar
83
Yes always use a Toyota thermostat. Glad you got it figured out!
kawazx636
Oct 6, 2021 03:03 PM
dbollier123
Sep 29, 2015 05:23 PM
Matthew Perez
Sep 28, 2015 05:43 PM
taraf
Sep 25, 2015 02:57 PM
LucasF249
Sep 8, 2015 01:17 PM
