Pre 84 Trucks 1st gen pickups
tire questions
Old Mar 19, 2009 | 03:14 PM
YotaTheKid's Avatar
tire questions
OK i've decided to get the 33 inch toyo mt's, now should i get the 33x12.5x15 or the 33x10.5x15 keep in mind im on a budget and if i get the 12.5s i have to buy new rims. thanks guys, btw i have an 82 with a 4 inch suspension lift if that helps you decide
Old Mar 19, 2009 | 03:42 PM
toy89yota's Avatar
10.50's imo but it depends on what you are going to be doing with your truck
Old Mar 19, 2009 | 05:58 PM
fyreandwater's Avatar
How wide are your wheels? 12.50's will fit on 8" rims which are pretty common. I have a four inch lift with 33x12.50's. It also depends alot on what you plan on doing with your truck. Narrow wheels are better for mud, but in my opinion 12.50's are better for crawl'in.
Old Mar 19, 2009 | 10:39 PM
YotaTheKid's Avatar
well they are 15x8 so the 12.5s would fit on there ok? i think i'm going to get the BFG KM2 tires instead the 33x12.5x15, i think they'll look pretty good and they basically look like the krawlers but the lugs aren't as deep so yeah and i mean they're BFG so you can't go wrong there especially since they are like 50 bucks cheaper for each tire hahahaha any other suggestions on tires? heres a pic of the rims i'm runnin now with my dinky 31x10.5 MTRs hahaha oh with the 12.5s do i need to have rims that have backspacing or should i just get wheel spacers or can i run them on the rims i have and still be able to turn the tires all the way without rubbing them on the leaf springs? lots of questions hahaha thanks guys i'm a tard when it comes to tires
Old Mar 19, 2009 | 10:44 PM
YotaTheKid's Avatar
Old Mar 20, 2009 | 01:43 AM
dropzone's Avatar
Fossilized
Get the 12.50's They are great on my '81
8" Rim with 3.5" BS
Old Mar 20, 2009 | 04:56 PM
12.50's will fit. You don't have to have spacers or backspacing. They may rub a little but there are adjustment bolts on the inside of the wheel that you can adjust so you don't rub when you turn.
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
