Pre 84 Trucks 1st gen pickups
22R Carb adjustments
Old Feb 21, 2007 | 09:28 AM
Traumahawk's Avatar
Can anyone point me in the right direction to find info on how to adjust my carb? I just got it rebuilt, but I can't seem to keep it running after I installed it back on the truck. I just need to adjust the RPMs, rich/lean. Just general info....some pics would be cool too. Anyone know of a post out there that might help?
Old Feb 21, 2007 | 04:20 PM
myyota's Avatar
When you rebuilt the carb did you take the chock assembly a part ?, if so, did you put it back together properly ?, are you sure that you got the vacuum hoses conected properly ?, have you checked for vacuum leaks ? did you try adjusting the idle screw ?, how did your truck run before you rebuilt the carb ?, when i got my truck, the previous owner had been screwing with the timing to try and make it run, once i rebuilt the carb and reset the timing my truck now runs perfect.
Old Feb 23, 2007 | 04:25 PM
Traumahawk's Avatar
The Carb was professionally rebuilt. Had an import carb rebuild place do the work. I just know enought to put it back together....I really don't know anything else. The truck did not run other than idle before rebuild. There ended up being a bad O ring in it. It is now built and clean. I just don't even know which screws are the idle screw...or what??? Really any help would be nice!
Old Feb 23, 2007 | 07:21 PM
myyota's Avatar
The idle screw is on the passenger side of the carb just below the fuel cut solenoid (the round thing with wires comming out of the back) its a screw with a spring around it. try adjusting it by turning it clockwise to raise the idle and see if that makes a difference.
Old Feb 24, 2007 | 04:03 PM
Traumahawk's Avatar
Thank you myyota!
Old Feb 25, 2007 | 03:58 PM
Traumahawk's Avatar
Can anyone that has a '83 truck take a picture of their carb, and vac lines, and post it here? I have 2 vac lines that I can't figure out where they go???
Old Feb 25, 2007 | 04:23 PM
20Rheadbanger's Avatar
You should have a diagram on the underneath of your hood , front passenger side that will show you.
Old Feb 25, 2007 | 07:18 PM
Traumahawk's Avatar
Ok headbanger, I will check that. Still would like a pic if someone would not mind.
Old Feb 26, 2007 | 05:48 PM
If I can get my camera workin I'll take a photo for ya and email it to ya, whata think?
Old Feb 28, 2007 | 11:52 AM
Traumahawk's Avatar
20R has an '80..wont help...Anyone have an '83???
Old Mar 2, 2007 | 12:52 PM
coryc85's Avatar
Trauma, I have an 83 and just rebuilt the carb, set the idle and adjusted the mixture, so maybe I can help you. I removed most of the vac lines except for the vac advance to distributor, PCV valve, and brake booster. There was a lot of lines that I plugged, either by routing them back to themselves or just capping them. I will try to get you a picture.
sandyota
Feb 4, 2021 11:16 AM
Higbee89
Aug 24, 2015 08:47 PM
insadj05
Aug 23, 2015 09:11 PM
87blyota
Aug 23, 2015 03:57 AM
