Pre 84 Trucks 1st gen pickups
20 r engine probs
Old Aug 29, 2007 | 03:39 PM
yoterr's Avatar
20 r engine probs
ok guys i have an 86' truck with a 79' motor with aprox 70,000 miles on it well i got it all swapped in the truck runs good at higher idle but wont idle at about 1,000 rpm has to be at least 2... another thing is when i drive it and i hit the brakes the engine tries to die out, but only when driving i can do this wile its idleing and nothing no idle change or anything..it has an electric fuel pump i dunno if this would be any prob, im gonna do a seafoam treatment tonight and see what happens thanks!
Old Aug 29, 2007 | 04:31 PM
slacker's Avatar
sounds like a vacuume issue .
Old Aug 29, 2007 | 04:33 PM
INFINITY's Avatar
vacc or carb settings. my bet is on the carb
Old Aug 29, 2007 | 04:34 PM
yoterr's Avatar
but it would still do it when i stomp the brakes when idling right? or at least change the engine rpms?
Old Aug 29, 2007 | 04:35 PM
yoterr's Avatar
yeah i just rebuilt my carb a little wile ago but its a mother@#$%#$ to tune
Old Aug 29, 2007 | 08:36 PM
4banginRunner's Avatar
agreeing with the vacuum issue and/or cab issue
vacuum line from the booster to the carb attached? working?
Old Aug 30, 2007 | 06:18 PM
yoterr's Avatar
ok im preeeety sure my carb is running lean wich way do i turn the screw to richen the mixture? and ill check the booster vac line tmr...to late to check now
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
