Pre 84 Trucks 1st gen pickups
Power source for stereo and cb
Old Mar 29, 2007 | 05:20 PM
WSUWESTON's Avatar
I am installing on a 82. What wire should I use for my power source for cd player and cb? One of the ignition wires? PLease describe where it is located and the color
Old Mar 29, 2007 | 05:28 PM
86toysr5's Avatar
on my stereo i jus ran it straight to battery taht way i dont need the ign on....i didnt do it but put a in line fuse in....run the wire threw the firewall
Old Mar 29, 2007 | 06:00 PM
91_4x4runner's Avatar
Do you experience any extra battery drain with it like that?
Old Mar 29, 2007 | 06:04 PM
WSUWESTON's Avatar
I did that when I was first starting with cars and had to turn off the stereo all the time. Did you set up a way to not turn off the radio and still not drain the battery? I do not drive the toy very often and don't want a dead battery every time I go to use it.
Old Mar 29, 2007 | 06:24 PM
86toysr5's Avatar
ive never had any problems and my dad does it to and either does he....when you think about it uses less power cuz the ign isnt on sending power to every thing else....when i had it set up in my 82 like that i had the radio going for about 3-4 hrs without starting it and it started like up(cant work on stuff without music)
just make sure u shut it off n you should be fine
Old Mar 29, 2007 | 06:26 PM
I think I'll do pretty much the same thing except using an inline switch just to save my butt...
Old Mar 30, 2007 | 09:33 PM
WSUWESTON's Avatar
Well I installed the sterio today with an ignition source rather than the battery. It works great. I ran all my wires for my cb but have not turned it on yet. For the cb antenna coax does it matter if it is ran buy my power and ground? Static?
Old Oct 7, 2007 | 05:28 PM
semo's Avatar
why don't you just pull out power from the fuse it's closer and easier isnt it?
Old Oct 7, 2007 | 05:43 PM
apalmer1's Avatar
If you want it keyed jsut run it to the keyed 12V for the cigarette lighters, thats what i did with mine. Also make sure that you run a permanent 12V cord to the hotwire for the memory, otherwise youw ill lose your presets/settings every time you remove the key.
Old Oct 7, 2007 | 05:58 PM
ozziesironmanoffroad's Avatar
he may not know this, and i sure as hell dont... there r a few red wires behind the bezel... and i dont have a cig lighter... had one in, but it started smoking cuz i had it on a hot wire.. which one is the keyed wire?
Old Oct 8, 2007 | 08:24 AM
WSUWESTON's Avatar
My Cig Lighter is not keyed, it just stays on all the time.
Old Oct 8, 2007 | 02:36 PM
deserttoy84's Avatar
on aftermarket stereos there should be a wire that runs to the battery(yellow wire) and one that goes to your ignition switch(red wire). Just wire it up like it says. For the cb just go directly to the battery(both positive and negative). If your cb doesnt have an inline fuse make sure to use one. Since your already wiring everything you might want to consider running an inline noise filter, there cheap and they help.
Old Oct 9, 2007 | 09:22 AM
WSUWESTON's Avatar
Thanks all. I finished wiring this stuff up about 7 months ago.
Old Oct 9, 2007 | 02:48 PM
Wow, i didnt even notice. why do people bump old threads
r3dfish
54
May 16, 2016 10:31 PM
theking11863
Mar 19, 2016 09:36 PM
Esibnitsud
Jul 30, 2015 08:19 PM
gmonnie123
Jul 26, 2015 02:44 PM
cyclist231
Jul 7, 2015 12:56 PM
