Pre 84 Trucks 1st gen pickups
Tranny swap?
Old Mar 11, 2007 | 08:06 PM
TLakeHarley's Avatar
Tranny swap?
Does anyone know what year trannies will swap with a 1983 4x4?
Old Mar 11, 2007 | 09:25 PM
MudHippy's Avatar
This'll give you an idea what should go behind what easily, transmissions & transfer cases.http://www.4x4wire.com/toyota/faq/parts/
These 2 have other good info.http://advanceadapters.com/toytruck.html
http://www.marks4wd.com/products/eng...lux-index.html
This one is just good Toyota transmission definitions.http://en.wikipedia.org/wiki/Categor..._transmissions
If your looking for a new transmission, transfer case or to rebuild then here.http://www.marlincrawler.com/htm/tra...ansmission.htm
Old Mar 11, 2007 | 10:42 PM
dcg9381's Avatar
Basically any pre-85 tranny will drop in and fit.
After 85, it'll bolt up, may require changes in the floor due to overall length.
Marlin builds great L51HD transmissions. Upgraded bearings, upgraded gearsets.
Old Mar 16, 2007 | 10:52 AM
4XTOYOTAX4's Avatar
Ive got an ifs (dont know the exact year) maybe 86-87 in my 82. Bellhousing and clutch are no prob, but you will need a new trans mount.
Old Mar 16, 2007 | 04:02 PM
MtnToys's Avatar
L series trannys will bolt right up. They are found on 83 and earlier trucks. Any 84-95 22re tranny (G or W series) will bolt up to the engine but they are longer then the early L trannys. So drive shaft and cross member work needs to be done if you use an 84-95 G or W series tranny. The pre84 L series trannies have weaker bearings and are more prone to failure then the later G and W series trannies. The L43 and 45 (4 speed) are supposedly weaker then the L50 and L52 (5 speed) trannies. Judging by the year of your truck you should have a L52 stock.
If you?re looking to put a G or W series in your truck, Budbuilt.com makes some killer cross members.
Dieselmann
Feb 19, 2019 02:57 AM
mskalmus
May 28, 2017 07:51 AM
yourrealdad
Jul 21, 2015 11:13 AM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
