Pre 84 Trucks 1st gen pickups
Ignition system swap
Old Feb 24, 2007 | 08:50 PM
flightforlife2007's Avatar
Is it possible to swap a newer electronic ignition system from like 86 or 87 into a 76 or does anyone have a coil power supply. Does anyone know what would keep a coil from getting power. There is no spark which leaves us without car...
Old Feb 25, 2007 | 06:31 PM
myyota's Avatar
Try this place, www.performencedistributors.com , they sell GM HEI distributors for toyota trucks. all you need is a single 12 volt wire to run this ignition system.
Old Mar 13, 2007 | 06:05 AM
Foxtrot's Avatar
you could always use an MSD system to bypass the toyota igniter
Old Mar 18, 2007 | 07:31 AM
jriebe's Avatar
I don't think that is entirely correct...I have been looking to do just that and all of my research has led to the conclusion that you must retain the stock igniter in circuit with any MSD product...correct me if I am wrong, that would be great.
Jon
Old Sep 9, 2007 | 10:21 PM
i got it running it just had a direct short to the distributor housing. the guy that put the new points in took off the nylon bushing and forgot to put it back on so the truck wouldn't start problem solved anyone want to buy it?
icentropy
Sep 16, 2020 02:47 PM
Sleaker
Aug 26, 2020 06:03 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
coryc85
Sep 9, 2015 06:24 AM
94whiterunner
Jul 12, 2015 07:15 PM
