Pre 84 Trucks 1st gen pickups
Choke not opening help!
Old Jul 3, 2007 | 01:13 AM
trekker81's Avatar
I've done a resistance check on the choke coil , its all within specs... I then did a power test to see if it was receiving voltage, there is no voltage reading from the terminal.. I've checked all fuses in the dash, tested voltage with the engine running , and with only the ignition switch on.. Has anyone else had any similiar problems ? Could it be a fusible link somewhere ?
Thanks for your time
Old Jul 3, 2007 | 04:13 PM
My814x4's Avatar
I think the choke gets its power from the coil.
Old Jul 8, 2007 | 04:51 PM
kj1074's Avatar
mine did the same thing. i bought a manual choke kit for $12. worth every penny.
Old Jul 10, 2007 | 06:09 PM
RallyRoach's Avatar
Sorry to hi-jack, but where did you get this kit? I've been looking for one for mine for a while, ever since the spring went sproing and I had to jury rig a pen spring.
Old Jul 11, 2007 | 01:05 PM
kj1074's Avatar
got mine at oreilly i think, autozone, carquest, napa; they all have them. its pretty simple set up, just get the line of pull with the least amt of bends and youll be ok.
Old Jul 11, 2007 | 10:31 PM
trekker81's Avatar
I finally found the problem , it was the charge light relay, replaced it, sensor & charger light is off and choke now opens.
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
dbollier123
Sep 29, 2015 05:23 PM
PNW94Runner
Sep 29, 2015 02:55 PM
Odin
Sep 26, 2015 06:56 PM
