Pre 84 Trucks 1st gen pickups
83 Truck is fine at higher RPM's but sputters and dies at idle
Old Jul 6, 2010 | 10:55 AM
piercejd83's Avatar
My 83 pickup has had a few problems of late and this is the last one that needs fixing. It sounds like a fuel issue to me, as its getting enough fuel to run at high RPM's but once it hits lower ones at idle, it will sputter and shut off. It's not an electrical issue, or at least I don't think so, because the music is still on when it dies. Help would be greatly appreciated!
Old Jul 6, 2010 | 10:57 AM
rebelrunner's Avatar
sounds like your oil pressure is to low.
Old Jul 6, 2010 | 11:28 AM
piercejd83's Avatar
the pressure meter says the pressure is fine, so it doesn't seem like an oil pressure issue to me. i was thinking it might be a fuel pump issue or maybe a carb issue
Old Jul 6, 2010 | 11:43 AM
carb maybe. fuel pump no be cuase if it cant push fuel at low rpm why would it be able to do that at higher rpms when you need more fuel. check the oil level and see where its at.
Old Jul 6, 2010 | 11:47 AM
piercejd83's Avatar
good point about the fuel pump. The oil level is good too
Old Jul 6, 2010 | 11:49 AM
maybe adjust your idle screw.
Old Jul 6, 2010 | 12:02 PM
piercejd83's Avatar
i think i might have found the issue, and i feel like an idiot for not finding it earlier. one of the vacuum hoses was unattached. it seems to be running fine now but does that sound like the problem?
Old Jul 6, 2010 | 12:07 PM
if it runs fine then it was the problem.
Alex Bessinger
Jun 28, 2015 10:05 AM
saphirekosmos
Jun 22, 2015 10:26 AM
slider417
Jun 22, 2015 10:18 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
gtpman98
Jun 16, 2002 01:16 PM
