Pre 84 Trucks 1st gen pickups
L52 Standard or HD?
Old Jun 24, 2010 | 07:34 PM
jdrjsbl's Avatar
Red face L52 Standard or HD?
One quick question to the one who knows. Over at Marlin Crawler they have the L52 Transmission they have under “Performance Type” a “Standard” and a “Heavy Duty” for an additional $100.00.
What’s the difference?
Please explain in a non-technical way (newbie).
Old Jun 25, 2010 | 02:11 PM
83's Avatar
83
Well...the L series 5speed tranny's had issues with a weak input shaft bearing. Undersized, so it would fail prematurely. Add larger tires to the mix (which everybody does with a first gen) and it's even worse. So if you just rebuild it the way it came, it still has that weakness. Drive the truck right and don't have huge tires and you're probably fine, but there was an issue with some of those bearings. Supposedly the L52HD has a later model gear set in it which accomadates larger bearings. So this would eliminate that weakness. For the money I think it's worth it...but then I have one...
They used to have a much better description on the site as to what the L52HD was, but for some reason they took it down. Now there's just a drop down menu to choose from with a "heavy duty bearing" option and no description. I don't know why they changed that.
Old Jun 26, 2010 | 10:41 AM
jdrjsbl's Avatar
Cool, thank you!
Old Jun 26, 2010 | 06:00 PM
shlobeck's Avatar
I agree with 83..I had an Crawler L52 HD installed into my '83.. For $100 it makes sense, especially if you do any off roading..
Old Jun 28, 2010 | 05:14 PM
jdrjsbl's Avatar
Will it be okay if I install it on a daily driver with some off-roading in between. I drive a 1982 Toyota Pickup 4x4 SR5.
Old Jun 29, 2010 | 03:41 AM
83's Avatar
83
As far as I know the HD has nothing to do with offroad. Sholobeck may have had some custom crawler gears put in his tranny, but the the L52HD is just stronger bearings. Last I looked on Marlin's site, the gear ratios were exactly the same for the L52 and L52HD. My truck is a daily driver, taken it from Montana to Arizona, 70mph. It's a regular old transmission, nothing "offroad". At least that's the way it was when I got mine.
Old Jun 29, 2010 | 11:19 AM
red1983's Avatar
I would do the HD, when ever I get to buying a new tranny, it will be the HD, and I won't offroad much, just once in a while.
Old Jun 30, 2010 | 04:43 PM
dropzone's Avatar
Fossilized
if I had the $$$, I would spend the extra $100 for the HD....i finally found a decent used L-52 on craigslist to replace the other one of broke...I should just suck it up and throw in a W-56 but don't want to move the crossmember 5" and redo my driveshafts (again)
Old Jul 7, 2010 | 04:12 PM
adamsbro1's Avatar
Get rid of the L series and get a W56 put in there!!! JMO!
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
voiddweller
Sep 28, 2015 11:21 PM
Toys4parts
Sep 26, 2015 01:56 PM
