Pre 84 Trucks 1st gen pickups
Front axle leaking
Old Jun 24, 2010 | 08:38 AM
slisdexia's Avatar
Front axle leaking
How hard is it to replace the seals around the axle at the birfield? Mine are leaking and there is enough dirt stuck to the axle that I'm a bit worried now. Is there another seal inside the axle that is supposed to prevent this?
I'm talking about the seal at the end of the axle on the end. It looks like a cheesy thing but like I say, there is a lot of garbage around there.
Do I need to look elsewhere? Should I look at rebuilding my axle?
Old Jun 24, 2010 | 08:46 AM
4Crawler's Avatar
Yes, inner axle seal, not terribly hard to replace, just messy:
- http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml
And if gear oil is leaking out of the axle housing, it has likely mixed with and washed out grease in the birfield and/or wheel bearings. So best to clean and inspect those parts while in there. I had a couple of wheel bearings go on my '85 axle due to an inner axle seal leak.
Old Jun 24, 2010 | 08:57 AM
SpecialScottie's Avatar
I would just rebuild it
Old Jun 24, 2010 | 10:13 AM
waskillywabbit's Avatar
Knuckle Service Kit has all the parts you need to rebuild like new.
Old Jun 24, 2010 | 11:24 AM
83's Avatar
83
Go with Marlin if you can, he's got larger inner seals that supposedly don't leak so much. I had mine done two years ago and they're already leaking again. It's a fairly cheap job to do yourself, and really expensive to have someone do, since it takes a full day. I had someone else do it...$600 and it's leaking again already.
Old Jun 24, 2010 | 10:50 PM
wentz912's Avatar
By marlin's kit and do it yourself. If you have a chiltons you can do it in a day no problem.
Old Jun 25, 2010 | 12:39 PM
slisdexia's Avatar
what is needed to pull the inner seal out?
do I have to remove the axle shaft? I'd guess I would
thanks for the responses
Old Jun 25, 2010 | 02:05 PM
83's Avatar
83
Yeah you have to take everything out. Tires, hubs, bearings, birfields, axle shafts. There are write-ups with photos online if you search. There are a couple special tools...a bearing pre-load thingy, and a tool to seat the inner axle seal, which can be bought or made. I haven't done it so I don't have specifics for you, but it's all out there, I've read write ups on it and looked a pictures a couple times.
oldirtydirt
Feb 23, 2020 09:30 AM
jasonty
41
Dec 23, 2018 01:00 PM
jerusry
Oct 19, 2015 05:28 PM
ItsJustD
Jul 7, 2015 07:49 AM
toyoda8488
Jul 5, 2015 10:18 PM
