Pre 84 Trucks 1st gen pickups
Ignition
Old Sep 20, 2010 | 09:45 PM
jcrespo's Avatar
Ignition
So I have a Jacobs Ignition setup that I got on ebay a while ago. Question is does anybody have experience with Jacobs on a 22R?
Old Sep 23, 2010 | 07:54 PM
jcrespo's Avatar
Anyone?
Old Sep 23, 2010 | 08:23 PM
myyota's Avatar
Most people here stay with the stock ignition system because its pretty much bullet proof as it is. The engines in out truck are not built for high performance so there is really no need for an after market ignition. All i can say is hook up your Jacobs ignition system and see if you notice any gains in power or gas mileage, and let us know your results.
Old Sep 23, 2010 | 08:36 PM
jcrespo's Avatar
I think I might do it this weekend then. I don't want to mess with a good ignition system if i don't need to though. decision..decisions. I have a friend with a coil to support the jacobs ignition so if i can persuade him to let me borrow it for testing then i will. If not I can just keep it for the tercel... BTW thanks for the reply!
Old Sep 23, 2010 | 08:58 PM
myyota's Avatar
My 4Runner has a 22RE, and the only thing i did to the ignition is upgrade to a higher output coil, the original coil had over 200.000 miles on it.
Old Sep 23, 2010 | 09:37 PM
jcrespo's Avatar
Higher output coil? My truck was previously owned by a guy who worked for a dealership so alot of parts are new but stock... for example the coil. It's new but I don't know about Higher output. Aftermarket?
Old Sep 24, 2010 | 12:09 AM
myyota's Avatar
Yes, aftermarket, swapped in a Accel Coil, its rated at 42000 volts. I have no idea what the stock coil was rated at, but most stock coils are rated in the 30.000 + volt range.
If you can, post a picture of your truck.
Kamaloha
Oct 16, 2015 05:13 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
voiddweller
Sep 28, 2015 11:21 PM
JHalcyonM
Sep 14, 2015 01:10 AM
