Pre 84 Trucks 1st gen pickups
First time gear install Tips or advice?
Old Jul 21, 2010 | 06:15 PM
BoredOutnJackdUp's Avatar
So im finally upgrading from my 4.10s on my 83 yota and am swapping in 5.29s this is my first gear install and was wondering if there was anything i should know? or anything to make it go smoother and less of a chance of bad turnout?
Thanks alot.
Old Jul 21, 2010 | 06:17 PM
slacker's Avatar
using a "spacer" from the /79-/80 and shims .. is a way better choice then a crush sleeve you have now ..
Old Jul 21, 2010 | 06:41 PM
Why is that? and where do i get those because i was gonna start on the install tomorrow
Old Jul 21, 2010 | 07:52 PM
waskillywabbit's Avatar
Solid Pinon Spacer such as this:
http://www.wabfab.org/Differential-S...-products.html
Old Jul 21, 2010 | 07:54 PM
dropzone's Avatar
Fossilized
gonna take a few cool tools to do the install.
you can find several great write ups at Zuk's website: http://gearinstalls.com/
edit: be sure to mark your carrier bearings side to side...
get a master install kit for each third member
Old Jul 24, 2010 | 01:00 PM
Gov't Mule's Avatar
Yeah, I HIGHLY recommend doing alot of reading before you start, and as Robb said, ZUK's website has a TON of helpful info. Also there is this:
http://www.4x4wire.com/toyota/tech/gear_setup/
Good luck....it's not hard if you PREPARE and TAKE YOUR TIME.
voiddweller
19
May 2, 2016 09:10 PM
85run
Jul 8, 2015 11:20 PM
hexrain
Jun 27, 2015 06:17 AM
bobbybouche
Jun 18, 2015 10:22 AM
