Pre 84 Trucks 1st gen pickups
1 Wire/ Elec Fan
Old Aug 6, 2010 | 09:42 PM
truckman1966's Avatar
1 Wire/ Elec Fan
Decided to make room for my gm power steering pump on the drivers side of the engine. so i decided to move my alt to the pass side, go one wire gm and go electric fan. i used the stock temp switch to control the fan, (comes on at 185ish) used the modified stock alt bracket on the opposite side and had to make the upper adjustment bracket for the top of the alt. all i have into this is $41 for the one wire and $8 for the right belt. (granted i work at a shop so i get parts really cheap). so far so good. finished it about 4 hrs ago and every thing works great. ultimately, there will be a saginaw pump on the drivers side of the block and i will be using a stock solid front axle power steering box.
Old Aug 31, 2010 | 06:28 AM
change of plans, mercedes diesel, hi steer and ifs power box
kawazx636
Oct 6, 2021 03:03 PM
voiddweller
Sep 28, 2015 11:21 PM
Matthew Perez
Sep 28, 2015 05:43 PM
runnermedic
13
Sep 21, 2015 05:20 PM
Aaron Logan
Sep 3, 2015 08:08 AM
