Pre 84 Trucks 1st gen pickups
"death wobble" on a 83
Old Aug 31, 2010 | 08:12 AM
4bytruckin's Avatar
stock 83 4x4. goes into death wobble on deceleration . what should i look for??
Old Aug 31, 2010 | 08:16 AM
xxxtreme22r's Avatar
loose steering components, wheel bearing play, ball joint play.
Old Aug 31, 2010 | 10:18 AM
kawasakimoto_7's Avatar
while braking? if its while braking it could be warped rotors, toyota rotors warp pretty damn easy.
and what xxxtreme22r said too could be it..
Old Aug 31, 2010 | 10:53 AM
Gov't Mule's Avatar
no ball joints on a '83
Old Aug 31, 2010 | 11:37 AM
i figured that, but left it up to the O.P. to figure that one out , wasn't 100% if the SA trucks had them. never had or drove a truck with SA, so.
Old Aug 31, 2010 | 12:13 PM
dropzone's Avatar
Fossilized
in addition to what has been mentioned check for worn spring bushings.
Old Aug 31, 2010 | 03:56 PM
4bytruckin's Avatar
yeah no ball joints. lol. everything is tight . no movement of the rod ends or the steering rod ends. definitly gonna check the bushings on the springs. and the rotors. it only happens when i start to decelerate not brake. if i down shift it stops shaking.
Old Aug 31, 2010 | 04:29 PM
Al's Chop Shop's Avatar
bad/blown shocks?
how bad are your springs?
Al
Old Aug 31, 2010 | 05:35 PM
4bytruckin's Avatar
springs have a slight negative arch. plan on checking the bushings 2marow. kinda just had my gall bladder removed. organ failure sucks
Old Aug 31, 2010 | 06:58 PM
4bytruckin's Avatar
no need to check the bushings. jacked the front end up again. hit the passenger side tire hard sideways, and thud. apparently the previous owner thought that just a cotter pin would hold the t.r.e. in place . that's right . no castle nut . just a bent pin. it bears repeating. no castle nut . just a bent pin. lucky for me i have a wonderful gf who wrenches on her 4x4's and she is coming to change it 2marow. just picked up a t.r.e. for 12.99 plus tax from auto zone. if i wasn't down from surgery it would get changed tonight
Old Aug 31, 2010 | 09:21 PM
myyota's Avatar
Just be glad it didn`t come loose while driving down the highway.
Old Sep 1, 2010 | 03:30 AM
Gov't Mule's Avatar
NO SHEEYIT!!!
Old Sep 1, 2010 | 09:26 AM
crap, that's scary!!! glad you got it figured out before something bad happened.
Al
ViperTT
Aug 14, 2015 05:27 AM
Yoter
15
Mar 15, 2009 04:44 AM
bulldog-yota
12
Jun 24, 2004 08:15 AM
Robinhood150
21
Feb 21, 2004 06:00 AM
