Pre 84 Trucks 1st gen pickups
22r internals which years will interchange
Old Jul 15, 2010 | 02:13 AM
mjfrawg's Avatar
have a 1983 4x4 and got to build engine smokes bad . but im not sure what year model the engine is.and have noticed that the kits are for 82 - 84 models & then 85 up with the 85 ups easier to find. question is will the rings, bearings & gaskets for the 85 up kits fit if its an 82 - 84 block.or is their a way to find out for sure what model engine i have
Old Jul 15, 2010 | 07:15 AM
Gov't Mule's Avatar
Measure your deck height.
http://www.lcengineering.com/TechNotes/TechNote49.htm
also look for the "laser" block id (see pic at bottom of LCE webpage)
1975 - 1980 20R Block
Deck Height 11.280"
Stock Bore 88.5mm - 3.484"
Maximum Over Bore 90.0mm - 3.544"
1981 - 1984 22R Block
Deck Height 11.280"
Stock Bore 92.0mm - 3.622"
Maximum Over Bore 93.0mm - 3.662"
Big Bore Forged Piston Kit 94.0mm - 3.701"
1985 - 1995 22R-22RE "Laser Block"
Deck Height 11.090"
Maximum Over Bore 93.0mm - 3.6662"
All Toyota 20R - 22R - 22RE engines use the same crankshaft and connecting rods. To accommodate the different deck heights, Toyota changed the compression height (piston pin location).
Old Jul 15, 2010 | 05:26 PM
mjfrawg's Avatar
appreciate it Gov't Mule now i know my engine is a 84 or older now the question is will 85 model rings,rod & main bearings & gaskets fit the 84 & older blocks ?
Old Jul 16, 2010 | 03:57 AM
Gov't Mule's Avatar
I'd contact the guys at ENGNBLDR they should be able to set you up with all the right parts. Quality is great and prices are good, I've gotten a bunch of stuff for my 1st gens from them.
http://www.engnbldr.com/
sandyota
Feb 4, 2021 11:16 AM
cars-guy
Aug 16, 2020 06:59 AM
young buck
18
Aug 27, 2018 02:40 PM
keithporter83
Jul 24, 2015 07:37 AM
cars-guy
Jul 11, 2015 07:51 PM
