Pre 84 Trucks 1st gen pickups
22re engine swap
Old May 22, 2010 | 11:56 AM
Nik's Avatar
Nik
22re engine swap
I have an 82 yota with an 86 22re motor. I'm running 37 inch tires and its pretty slow on the freeway, and I was wondering if putting a 6 cylinder in it would help at all, and if so what kind of motor should I put in? I just got my yota a couple weeks ago and its my second vehicle ever, so im still pretty green to all this.
Old May 22, 2010 | 12:02 PM
mightymouse's Avatar
welcome. Search a little on gears and what to run for your engine and transmission. 5.29's should be cheaper than a motor swap.
Old May 22, 2010 | 12:11 PM
adamsbro1's Avatar
if nothing else just rebuild a more powerful 22re, there are alot of upgrades for these motors out there, and in my opinion if your gonna swap motors you may as well go all out and put a v8. i am rebuilding a 22r for my 82 in the garage so when i go to swap it will be out with the old in with the new no changing motor mount locations and stuff. just out and in of course its gonna take time cause getting the new to be in tip top running condition takes time. but i use it as a daily driver so i cant have it down for too long at one time and i dont want to loose the gpms of that stout 4cyl. eventually ill have a 302 in it but for now just a beefed up 22r. CARB'ed not EFI, i dont like electronics lol.
Old May 22, 2010 | 04:37 PM
Nik's Avatar
Nik
I like the higher ratio diff's idea, never even thought about that. I also like the idea of beefing up the 22re because gas is a huge factor, and the 22re's are bulletproof. Thanks for the info!
Old May 22, 2010 | 04:50 PM
adamsbro1's Avatar
Check out www.LCEperformance.com also do a search on eBay for "engnbldr" his name is Ted hell of a guy and he has a bunch of stuff for the 22r/e and he will answer any questions you have like I said he is a hell of a guy
Old May 22, 2010 | 05:59 PM
yoder519's Avatar
yea check out marlincrawler.com o rtrail-gear.com. you can get complete 8in diffs (3rds) and just swap them in. 5.29s would be ideal. tehn if your not happy..... 4BT Cummmins swap
Old May 22, 2010 | 08:30 PM
Nik's Avatar
Nik
You guys are awesome, and its a 22r not a 22re haha sorry about that. And would I need to get the same ratios on both my front and rear diff's?
Old May 22, 2010 | 09:05 PM
adamsbro1's Avatar
Yes do both at same time or you'll break when you use the 4x4! TRUST ME!! A couple more places you can look are www.allprooffroad.com. And www.northwestoffroad.com
adamsbro1's Avatar
Sorry for the language habitual typing lol!
Old May 22, 2010 | 09:25 PM
Nik's Avatar
Nik
Haha yeah thats what I thought I just wanted to be sure
Old Jun 5, 2010 | 05:42 PM
myyota85's Avatar
so whats the deal about the 4bt cummins???
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
coryc85
Sep 9, 2015 06:24 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
CJ94yota
Jul 3, 2015 10:14 PM
