Pre 84 Trucks 1st gen pickups
questions about swapers
Old Sep 3, 2010 | 10:45 PM
80toyota's Avatar
i got a set of swaper that are pro comps and they are 33/12.5/15 and i wanted to kno how many people regear or what do u think i should do regearing would be nice but dont got the money right now dose any one have any info have u had swamps or any thing i got the 22r and i wanted to kno if i would have any problems getting up hills threw mud or any thing or would i have to regear to do stuff like that?
Old Sep 3, 2010 | 10:55 PM
camo31_10.50's Avatar
SEARCH....this is covered DAILY...and is even stickied.
i'm not willing to help with a post like this....
use punctuation too.
Old Sep 3, 2010 | 11:02 PM
BoredOutnJackdUp's Avatar
No need to be rude camo.
But it will do fine most likely.
I have stock gears and ran 35x15 boggers and a decently built 22r/
and i only really had problems with going free way speeds.
you'll be fine until you have the money to do it.
in 4lo it'll do great, but go with 529s or lower when you do gear
Old Sep 3, 2010 | 11:08 PM
80toyota's Avatar
ok thank u i dont kno much about trucks i used to race not 4by ... would u recomand putting lock right lockers in the rear/front or leavig it stock for now?
Crimson Yota's Avatar
Here's a site that I've found rather helpful:
http://www.brian894x4.com/Gearratiosanddiffs.html
Shows you how to tell what ratio you have and what you'll need to run what tire.
Recommended gear ratios are about 3/4 of the way down.
Hope that helps, Camo's right though, you should search, it is kinda hard to find stuff on this site sometimes though.
Old Sep 3, 2010 | 11:10 PM
i would do a lock right in rear and a selectable or something in front when you have the money. i just run open diffs and spin circles around everyone on the trail, but im gonna stuff in gears and a rear lock rite soon
80toyota's Avatar
and i dont plan on using the tires for on road use only off road.
Old Sep 3, 2010 | 11:13 PM
80toyota's Avatar
selectable as in?
Old Sep 3, 2010 | 11:14 PM
not being rude...just find it kind of stupid that people these days that have access to a computer...can't use punctuation..makes stuff hard to read
i had 31" swampers...did circles around all the fullsize trucks and the jeeps in my area in the mud..in my '80 4x4...if i would have had a set of 33" boggers and lockers...it would have been UNSTOPPABLE.
ARB.
E locker.
selectable means you have the choice to have an OPEN differential (like stock) or you can flip a switch and LOCK the axles together.
Old Sep 3, 2010 | 11:18 PM
80toyota's Avatar
okay so the stock on would work for a while ? if i put the lock right in or would i have to change them both at the same time?
Old Sep 3, 2010 | 11:19 PM
exactly and point taken camo =)
But if its just off road go lock rights f&r
or just weld em. alot cheaper! and if your good at it just as strong!
Old Sep 3, 2010 | 11:20 PM
you could do at different times. but not needed for us yoders.
regardless these things dominate,
Old Sep 3, 2010 | 11:23 PM
80toyota's Avatar
the tires are the only thing that is off road only . i drive the truck all the time. but for now i shouldnt have to do any thing with the locker or any thing like that right. i should have no problems getting throw any thing?
Old Sep 3, 2010 | 11:25 PM
oh gotcha.
Yeah you'll have no problems.mine is my daily driver and i run open diffs stock gears and 35s and it goes anywhere i point the wheels.
Old Sep 3, 2010 | 11:26 PM
80toyota's Avatar
ok sounds good i got to get a lift now cuz the 33s hit the drag link
Old Sep 3, 2010 | 11:30 PM
your best bet is either www.trail-gear.com or do chevy 63s in the rear and rears up front.
Old Sep 3, 2010 | 11:32 PM
80toyota's Avatar
okay thank u any thing else that might help me?
Old Sep 3, 2010 | 11:34 PM
what else do ya need? i eat sleep and breathe 1st gens haha.
Old Sep 3, 2010 | 11:36 PM
80toyota's Avatar
idk im new to 4byin i raced sence befor i got my licens in honda so
