Pre 84 Trucks 1st gen pickups
questions about swapers
Old Sep 3, 2010 | 11:37 PM
80toyota's Avatar
if i did a 3 in left would i need high steering?
Old Sep 3, 2010 | 11:39 PM
BoredOutnJackdUp's Avatar
You dont need it, but it would sure help.
Its really nice to have, it depends on the tire size you wanna run.
and if your tires arent rubbing on the body but on the leaf springs or something it can be fixed with wheel spacers.
Old Sep 3, 2010 | 11:40 PM
where do you live?
Old Sep 3, 2010 | 11:41 PM
80toyota's Avatar
i live yelm wa. and it only hits the draglink when i make right hand turns. and y would it help just better clearence?
Old Sep 3, 2010 | 11:46 PM
  #25
yeah it will set the tires out further, give it a wider stance and fix the rubbing and alot cheaper and easier than a lift, to hold you over until you jack it up
Old Sep 3, 2010 | 11:50 PM
  #26
80toyota's Avatar
but could i put shacles on there ? to get that 2 in lift ? and i went to the 4by place and they want 350 for a 3 in lift and 86$ per spacer
Old Sep 3, 2010 | 11:53 PM
  #27
80toyota's Avatar
could i use shackels
i asked the 4by place close to me they want 350$ for 3 in lift and 86 per space ..
Old Sep 3, 2010 | 11:56 PM
  #28
Champ's Avatar
Dont forget the hysteer if you do a lift.
Old Sep 4, 2010 | 12:02 AM
  #29
80toyota's Avatar
so looking about 400 for hysteering and the lift kit?
Old Sep 4, 2010 | 01:22 AM
  #30
dropzone's Avatar
Fossilized
High Steer:
$300 for the kit:http://www.trail-gear.com/high-steer-kits
IFS steering box: $75-150 depending on where you find it or more if you go with rebuilt:
http://www.trail-gear.com/ifs-steering-boxes
IFS mounting bracket: $40-50
Old Sep 4, 2010 | 02:01 AM
  #31
80toyota's Avatar
would i need the high steering kit and the IFS steering box with the IFS mounting bracket or would i just need the high steering kit?
Old Sep 4, 2010 | 03:39 AM
  #32
xxxtreme22r's Avatar
just an fyi, I am not lifted, on 31's and running open open factory grears. You would be surprised what these things can do in nearly stock form. Our last Yotatech meetup at Rausch Creek off-road park, I went 90% of the places the other guys on here that were running 33's and a lift or 35's and even bigger lift. What I wasn't willing to do was most of the hills and severe off-camber. (I just don't like em). Most of the crawling with a proper spotter like Lumpy on here and proper use of the skinny pedal, you can get through almost anything that a guy running a 4" lift and 35s can.
Old Sep 4, 2010 | 09:45 AM
  #33
80toyota's Avatar
okay cool
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
