Pre 84 Trucks 1st gen pickups
Electrical Radiator Fans
Old Aug 29, 2010 | 04:43 PM
jcm151's Avatar
Anyone have any recommendations or experience with putting a electrical fan into a 82 Hilux?
My radiator has cracked and I have to pull and replace it so I am thinking about going to a electrical radiator fan and I am just looking for any information you guys might have.
Thanks in advance!
jeremy
Old Aug 29, 2010 | 06:40 PM
myyota's Avatar
This has been covered many times, do a search and you will find all the information you need.
Old Aug 29, 2010 | 06:42 PM
xxxtreme22r's Avatar
would the taurus fan mod actually work with an 82? I know it will work on the 86-95 ones. Although I am sure any aftermarket electric fan setup would work as long as you follow the directions on the kit.
Old Aug 29, 2010 | 06:45 PM
jcm151's Avatar
Could you give me the search parameters you used? Cause I tried 3 different searches and I did not find what I was looking for.
Old Aug 29, 2010 | 06:47 PM
Swimmerboy2112's Avatar
I wired up my electric fans on my Camaro to a switch so i can flip them on for regular driving and flip them off for racing for more power. The switch is wired directly to the battery so they will stay on even if the car is off. If you dont wanna worry about doing it that way, you could wire them to, lets say the cig lighter so they are always on when the truck is on.
Old Aug 29, 2010 | 06:51 PM
"electric fan swap" maybe? https://www.yotatech.com/search.php?searchid=7756899
Old Aug 29, 2010 | 07:57 PM
jcm151's Avatar
This is exactly why I asked the broad question about the electric fan. Yeah I mean I can always go get a electric fan kit and bolt it in there. I am looking for cheap mods that are tried and true. I can't find the specs on the 86 and up radiators if anyone could chime in on the mercury swap for a older hilux that would be great.
I am going to do more research if I figure out something good I will do a write up for future reference.
jeremy
Old Aug 30, 2010 | 05:03 AM
waskillywabbit's Avatar
Use a 2 speed Taurus fan with a dc controller.
Tons of info on here and Pirate.
Old Aug 31, 2010 | 06:25 AM
truckman1966's Avatar
or you could get tricky with it like i did and run constant power to your elec fan and run a 3/8npt temp switch that closes at 185 deg f and use it to switch your ground. then you never have to worry about them staying on and draining your battery incase you forget. and they won't run constantly and burn up the motor.
Old Aug 31, 2010 | 06:27 AM
https://www.yotatech.com/forums/f114...ec-fan-217651/
voiddweller
May 20, 2021 07:58 AM
coryc85
Sep 9, 2015 06:24 AM
Ohio4Runner
Aug 31, 2015 05:45 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
