Pre 84 Trucks 1st gen pickups
Help! Head Gasket
Old Oct 2, 2010 | 06:22 AM
83SR5YOTA's Avatar
Help! Head Gasket
I have a re-manufactured motor for my 83 Toyota and I think the head gasket is going and it has 20,000 miles on the motor. I think the company that built the motor used crappy gaskets when they built it so I'm not surprised. It started smoking so I pulled out the spark-plugs and one of them was wet. I checked the oil (no water) and I checked the radiator (no oil) and the level was some what normal. I know I should do a pressure test on the cooling system before I assume it's a head gasket, but I don't know what else it could be. This would be my first head gasket rebuild so I'm wondering what advise anyone could give me. Plus I was wondering if anyone had a step by step write up (and photos) about a rebuild you have done. Please help... Thanks
Old Oct 2, 2010 | 06:35 AM
83SR5YOTA's Avatar
Oh, and another reason why I think it's the head gasket is that it had a 190 thermostat when I was down in Texas for 3 months and it was running a little hot. Never close to the red but warmer than usual. I moved up to ND and put a 180 in it and it was running great. but I think the drastic change in temperature had something to do with it. Just an idea...
Old Oct 4, 2010 | 05:14 AM
eurospec1's Avatar
That change in temp would not affect the head gasket
So right now you have smoke, no oil in water, no coolant loss, and a wet spark plug. Was it wet with water or gas? Is the smoke, blue (oil), white that smells like celery (coolant), or black (running rich)?
I woudnt jump right to a head gasket, do a coolant system pressure check and a compression test, could be something as simlpe as a valve seal, run your checks sir!
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
themightykhoner
Aug 11, 2015 07:37 PM
Coreyr384
Jul 10, 2015 11:13 AM
