Pre 84 Trucks 1st gen pickups
1982 4WD 5 speed trans & transfer case issue
Old May 8, 2010 | 11:38 AM
glidercoach's Avatar
I have found that my transfer case is somehow pulling oil from the transmission. When I checked the levels, the transfer case has way too much oil and the transmission way too little. After I bring both back to their proper levels, when I check them again after a month or ?, I find the same problem. Any suggestions?
1982 Truck 4WD with a 1994 22RE powerplant.
Old May 10, 2010 | 05:25 AM
83's Avatar
83
There is a gasket between the two. There's also a shaft between the two that has a gasket around it. If you don't have any more major problems, replacing those may help.
Old May 10, 2010 | 07:09 AM
Thanks...I rebuilt the transmission last year and used the gaskets I was sold. I assume I was sold the proper gasket set.
Old May 10, 2010 | 08:04 AM
83's Avatar
83
Hm, interesting. I don't know much about the inner workings, so I won't be much help. The Marlin Crawler forum is really good for questions like this.
Old May 10, 2010 | 06:14 PM
Thank's I'll try it.
kazuya2416
Apr 5, 2024 02:17 AM
mskalmus
May 28, 2017 07:51 AM
crashburnoveride
Jul 10, 2015 06:39 AM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
